Rigid Tapping - Thread Question
RJS100
Post by RJS100 »
I started on my first project that requires tapping a total of thirty 1/4 x 20 holes in 6061 aluminum (see attached). I completed rigid tapping fifteen of them today and have one question. When you tap a hole, should the screw thread into the hole easily, or should you have to work it a bit. I found that once I got the screw started, I could easily turn it in with an allen wrench, but when turning it by hand, there was a bit of resistance.
Notes:
The tap I used has an H3 pitch diameter limit: https://www.mcmaster.com/catalog/130/2923/2529A18.
I tapped these threads at 700 rpm.
Is the fact that the screw fits tightly in the threaded hole because of the H3 pitch diameter rating of the tap, or do I need to tweak one of the rigid tapping parameters somewhat?
Best... Richard
Re: Rigid Tapping - Thread Question
I am not a machinist, so I am sure others here will have ideas better grounded in reality. But my take is:
1) In tapping (as opposed to thread milling or lathe threading) the fit is determined almost entirely by the size and shape of the tap.
2) You might get a slightly looser fit if you tap each hole twice (which you can do, with rigid tapping).
RJS100
Post by RJS100 »
Thanks. These holes .75" deep. I tapped them once at .375 and again at .75 and they feel better. I do think the H3 pitch diameter also makes for a tight thread.
Best... Richard
I'm sure you've checked, but have you tested in wax? If there are any inconsistencies in pitch from an incorrect encoder setup, you could be "pulling" the last couple of threads.
RJS100
Post by RJS100 »
Thanks Tom. I did indeed test in wax and all looks good. I have some other holes to tap in on my next project and the taps I will be using have a more "relaxed" fit. I think that is the culprit.
Have a great day... Richard
I would also use another tap for a looser fit.
On soft metals, I prefer thread forming.
RJS100
Post by RJS100 »
Hello Uwe,
I will be using another tap for my next project. I have been using the GWizard to get a starting point for the speeds & feeds.  With aluminum, I am beginning to get an idea as to what is in the ballpark.  But when I work with some new material that I have never done before, I have no idea.  For example, the attached is a set of jaws for talon grips I am making from 1018 steel.  I used GWizard to estimate the feeds and speeds... but some look a little aggressive to me.   We will find out in the next few days!
Jaws for talon grips: https://www.dropbox.com/scl/fi/6s8gmfjp ... wr56q&dl=0
Thanks... Richard
i moved this post into the machining strategies forum! :D
RJS100
Post by RJS100 »
Thanks Keith.
