Part Zero?
Part Zero?
Am I correct in my assumption that using the =0(zero) button on the WMPG is equivalent to setting the part zero in the part setup menu?
Re: Part Zero?
That button is setting the selected axis in the active WCS to Zero.
Maybe your desired part 0 edge is at this point also
Re: Part Zero?
I am calibrating the X axis mm/Rev. In Marty's video he says to reset part zero every time.
Re: Part Zero?
Yes part 0 and WCS 0 could be called the same thing....
For my wording I have in mind where I want to have 0 on the part, and then I set WCS 0 to this point
