so I am not an expert, at all. But I would really appreciate the opinion from someone who knows a lot about the Centroid control systems and other systems like Beckkhoff, Heidenhain, Fanuc, Mitsubishi, Siemens.. industrial CNC controls in general.
I only know words like xxx blocks look-ahead, kHz/MHz step frequency (always confused already there, is that usually per axis or in total? Would make a lot of a different number if that number is total on a 5 axis simultaneous operation I reckon..), xxx milliseconds/nanoseconds refresh rate and so on. Don't really know where the bottleneck usually sits with that though. I pretty often maxed out previous controls causing them to jitter and not get behind the G-code input, already with smoothing filter turned up etc. - not knowing what's the fault - control, motors/drives, code or something in between.
Now, when I talked years ago with someone from a machine tool builder in Germany, he told me pretty much all these entry systems (like EDING CNC in Europe) are not fast enough, there was one entry system (Beamicon Triple Beast) which had a 2MHz max step frequency it could handle (per axis/in total?). He told me if I want to do high speed work there is no way around something like a Beckhoff control, where the industrial PC alone would be 1400€ before tax, with servos and servo drive prices similar to Yaskawa 7 series.
When I look at the brochure of the Delta A3 servos they are talking about 4Mpps (mega points per second) maximum input step frequency at pulse + direction. Now when my control is talking kHz, and my feed is somewhere at 15m/min, the bottleneck would be obviously the control if I'm not mistaken? And when adding a linear encoder on all axis additionally, things get only worse for the control in terms of handling surfacing and such?
Would highly appreciate some input there from someone. Also, which control and what type of servos and drives would be most beneficial for high speed high feed surface machining? Would the Centroid Oak control make any difference compared to the Acorn?
And what's exactly the difference in all that between a Centroid, for example, Hickory and a Fanuc control with High speed machining option? Fanuc explains it as "High speed machining options provide look ahead, enhanced acc/dec control, and automatic feedrate control to increase both speed and accuracy". Would the same kind of performance be feasible with an Acorn control?
Asking because I would love to use Acorn. I like the community behind it, I like the pricing, I like all the how-to's and resources, I like that they are not some Chinese Fanuc rip-off from Aliexpress and not some "Request for quote" and "get in touch with our technician" type of company.
- Simon
