Undefined PLC Messages
Posted: Sun May 19, 2024 11:32 am
by NeilS
Allin1DC with CNC12 V5.10
I installed the standard mill PLC when prompted during the install but I am getting loads of Undefined PLC messages thrown up
See picture
Re: Undefined PLC Messages
Posted: Sun May 19, 2024 2:30 pm
by tblough
If you had included a report, we could check that the plc message file matched the plc file that was loaded. These undefined messages usually occur because the PLC file and the message file are from different revisions or configurations.
Posted: Mon May 20, 2024 2:11 pm
by NeilS
[Here is the report.zip
For clarification this was a fresh install from the latest CNC12 V5.10 install shield on a new PC. Neither the PLC nor the message file have been edited, o it looks like an error in the install shield.
Posted: Mon May 20, 2024 5:07 pm
by cncsnw
According to the report_*.txt file, that is v5.08, not v5.10.
It appears that your plcmsg.txt file is missing altogether.
Posted: Tue May 21, 2024 2:28 am
by NeilS
Where do I get a copy of the file then? As I said this was a clean install in January so I would expect it just to work. If I update to the latest how do I keep all my settings?
Posted: Tue May 21, 2024 7:10 am
by tblough
The easiest way is to do a re-install carefully following these instructions:
https://www.centroidcnc.com/centroid_di ... ctions.pdf
Or, since the exe installer is just a Zip file, you can open it with something like 7Zip, and extract the plc message file from the same subdirectory as the PLC file you originally selected.
Posted: Tue May 21, 2024 4:20 pm
by Centroid_Tech2
The "Undefined PLC Message" is due to a missing file that wasn't installed when you selected "Install - and keep existing machine configuration".
Since you have setup your machine configuration already, make a report of your current settings..(which you've already done).
Now do a fresh install and this time when installing the plc program, choose "Install - and overwrite existing machine configuration".
After the installation is complete, restore the report you made and let it overwrite files.
Posted: Tue May 21, 2024 5:43 pm
by tblough
If you are going to restore the report you posted, make sure you re-install 5.08 and not 5.1.
