Torch stops and Rises up
- Plasma CNC Controller: Yes
I run a CnC plasma but instade of firing the torch stops and Rises up. Could this be something that would be solved within the software..
Re: Torch stops and Rises up
Your Machine with Acorn Mill is Controlled by the Gcode completely.
If the Job stops without an error in the message LOG. it was most Likely something in the Gcode.
If there's a question of why a Job stopped. Attaching the Gcode Job with the post would Help A lot.
