V5.1 Lathe distance to go isn't working <misunderstanding>
When running a program the X display of distance to go is showing zero.
- Plasma/Laser Lead
Re: V5.1 Lathe distance to go isn't working
I was not able to replicate the issue with your report.
Usually, the X moves in the G-code I tested with was very short and the distance to go was shown briefly since the X move was very short and quickly executed.
Phil,
Did you have this issue on the runtime graphics (RTG) display; or on the G-code display; or both?
I will run it again when i am back at the workshop.
The RTG screen and the g code screen are both showing zero when it has to remove 6mm off the diameter.
When it is facing the end of the part off the distance to go on X and Z work ok. But when turning the diameter the X axis just reads zero on distance to go. sometimes 0.0002
I can show you a photo if you like.
- op1 Oil filter bolt.lth
- (1.67 KiB) Downloaded 9 times
- report_E0623470B40F-0819215108_2024-04-29_13-45-22.zip
- (1.14 MiB) Downloaded 11 times
Distance to go shows that amount of movement remaining in the current G-code line. It does not show the amount of material to be removed from the part.
AH! thank you for explaining that. It's a constant learning curve.
