On the offset page the ATC button has dissapeared from the screen menu.
It was useful having the ATC button on the tool offset page now i have to exit and go to the MDI screen to change tools on the lathe turret.
V5.1 Lathe ATC has vanished
Re: V5.1 Lathe ATC has vanished
Parameter 6?
You just waved a magic wand and now it is back on the screen again.
all your issues are from
intended work flow is: you must use write settings to cnc control at least once before moving the custom tool change slider to YES. we will make this more clear in the next version.
Ok
