Page 10 of 12
Re: No motor movement
Posted: Thu Jan 31, 2019 4:00 pm
by Kutton
martyscncgarage wrote: ↑Thu Jan 31, 2019 7:45 am
Was this router running fine under Mach3 via parallel port? If so what breakout board were you using.(make and model please)
Your video shows the router moving albeit jerky. Is that running under Acorn?
Where are you located?
I was using a SainSmart 4 Axis Mach3 USB CNC Motion Controller Card Interface Breakout Board
Router was running fine in Mach 3 using USB port
Meridian TX
Posted: Thu Jan 31, 2019 5:20 pm
by Richards
Let's review the basics. Disconnect the motor from the Acorn board. Connect ONLY the power supply wires to the driver.
1. Do you have a green light on the driver when you connect power to the driver and no motor attached? (My DM542 drives give a green light when power is applied to the drive with no motor attached.)
2. Do you have a green light on the driver when you connect power to the driver with a motor attached?
3. Use a fresh 9VDC battery. With only DC power connected to the driver's power connectors, connect the battery's GROUND terminal to Pulse (-) on the driver. Connect on end of a 1/4 watt or 1/2 watt 700 ohm to 1000 ohm resistor to the battery's PLUS terminal. Rapidly tap the other end of the resistor to the CW230 driver's Pulse (+) terminal. You should see the motor stepping . (The resistor should be used because the CW230 driver specs call for 7mA minimum to 17mA maximum current for the opto-couplers to work properly. The resistor limits the current from a 9V battery to be within those limits.)
If those steps work, then you know that the CW230 stepper driver is working, that the stepper motor is connected properly to the driver and that the pulse opto-coupler is working.
4. With power off, reconnect the driver's Pulse terminals to the Acorn. Do not connect the Direction terminals nor the Enable terminals. On the Acorn. click Setup, then Config (enter the default password - 137 unless you've changed it), then Parms. Push the Page Down key until you see the screen that shows P900 -P999. Use the arrow keys until Parameter 968's value is highlighted. Enter 30 to set parameter 968 to 40,000 steps per second. CLICK THE SAVE BUTTON OR PUSH F10 TO SAVE THE 968 PARAMETER.
5. Repeatedly push the ESC key until you are at the main screen. Select x100 on the Axis Motion Controls screen. Push either the plus or minus key for the axis to which your driver is connected. Without the Direction leads connected, the motor will only turn in one direction.
6. If the motor turns properly, shut things down and connect the direction wires from the Acorn to the driver. DO NOt CONNECT the Enable wires. The spec sheet says that they can be left unconnected - which is how i have things with my DM542 drivers. Turn power back on and jog the motor. This time it should reverse direction depending on whether you push the (+) or the (-) key for the axis.
7. If everything works, then connect each axis, one at a time, and test that axis before connecting another axis.
I've often had problems bringing up various process control boxes that I've designed. Going through the process, step by step isolates any problem. If you discover a problem, fix it before continuing.
Posted: Thu Jan 31, 2019 6:47 pm
by Kutton
Richards wrote: ↑Thu Jan 31, 2019 5:20 pm
Do not have a green light
2. Do you have a green light on the driver when you connect power to the driver with a motor attached?,
No green light
Do not have any resistors.
Do not have any enable connections wired.
What will I be in to enter password ?
Posted: Thu Jan 31, 2019 6:57 pm
Kutton,
What City and State do you live? Perhaps there is an Acorn user willing to come by and lend a hand. You are certainly struggling.
Did you build the Mach3 system or did you acquire it with the control installed?
Posted: Thu Jan 31, 2019 7:29 pm
by Kutton
martyscncgarage wrote: ↑Thu Jan 31, 2019 6:57 pm
Kutton,
I built it and did all electrical.
I live in Merldlan TX which is in central Texas
Dose the enable terminals need to be wired?
Posted: Thu Jan 31, 2019 8:05 pm
by Richards
According to the specs, the "enable" is actually "disable". When that signal is on, the drive is disabled. That's why the specs state that the "enable" is usually left unconnected. I do not have the "enable" signal wired on my DM542 drives nor did I ever wire it on the Geckodrive stepper drivers or on the Oriental Motor stepper drivers.
Posted: Thu Jan 31, 2019 8:46 pm
by Kutton
Richards wrote: ↑Thu Jan 31, 2019 8:05 pm
Where do we go from here. I feel it is a simple fix.
Posted: Thu Jan 31, 2019 9:01 pm
by Gary Campbell
A point of clarification: You say: "No green light"
Does this mean there are no status LED's on the drive, or that ones that are there are not lit?
Posted: Thu Jan 31, 2019 10:01 pm
by cncman172
Do a simple test. Is the stepper locked when powered? If you can spin the motor with drives powered then the driver is not enabled
Russ
Posted: Thu Jan 31, 2019 10:45 pm
by Kutton
Gary Campbell wrote: ↑Thu Jan 31, 2019 9:01 pm
The drive has a green status light but not lit.
I made share that the controller was connected to computer by pinging controller address.
