Build Thread: Ramsay CNC Plasma Question
Moderators: cnckeith, Joey
OceanFab
CNC Control System Serial Number: C165679
Re: Build Thread: Ramsay CNC Plasma Question
Post by OceanFab »
I connected two wires with lose ends to Out4, which I have never connected to, for experiment.
I am not turning Out4 on through the controller.
When I force NC (led on) and test for resistance, I get none, which makes sense.
When I force NO (led off) and test for resistance, I still get none, which, to me, makes no sense.
Am I not comprehending something?
For the Output board, all the lights are green when it is connected.
So looks like bad I/O board unless there is a way to turn them red, as in the acorn install manual.
Joey
Plasma/Laser Lead
Post by Joey »
If the Acorn's Output L.E.D's are working but the Relay board's Led does not match the output change then it does sound like the Relay board is cooked.
I doubt the Ribbon cable is the issue, but it should be tested to make sure there's breaks
Next step is to replace the Relay board.
OceanFab
Post by OceanFab »
The new relay board is in, but the lights are all green and not corresponding to the H10, which shows all red.
report_3484E41A16E5-0112247823_2024-10-11_11-34-23.zip
(5.79 MiB) Downloaded 16 times
