acorn with an old shopbot
luke
Re: acorn with an old shopbot
Post by luke »
I tested the power supply and am only getting 19 volts
Gary Campbell
Post by Gary Campbell »
Is that with nothing connected to the power supply?
luke
Post by luke »
that is when nothing is plug in to it
The power supply has two outputs, +5VDC and +24VDC. Disconnect everything from the power supply except L, N, and Ground. What is the 5V output reading? What is the 24V output reading?
luke
Post by luke »
I am getting 5 volts and 19 volts. I have a new power supply coming now.
Ken Rychlik
Post by Ken Rychlik »
Did you try to adjust the voltage? There is a white adjusting knob in it.
Ken
luke
Post by luke »
Yes it did nothing
luke
Post by luke »
I just got my new Meanwell power supply and board lights up and I have communication with the computer
centroid467
Post by centroid467 »
If you have everything else still disconnected, I would go through and verify all the connections with a multimeter. That should catch a potential wiring mistake that may have killed the MeanWell and at the very least give some peace of mind. It is also possible it was an uncommon random failure.
luke
Post by luke »
I did redo all the connections I actually think the power supply was a little on the weak side as so of the problems I had ongoing are now cleared up. Such as not always starting up and the limits not always working.
