Z Axis Plunging too Deep into part < part zero, tool offsets, turns ratio >
Re: Z Axis Plunging too Deep into part
When you run another program, you have to reset part zero. (Assuming it uses the same tools in the tool library)
milling
CNC Control System Serial Number: 3859
Post by milling »
Thanks Marty- I will make sure I do that. It seems the best measure at least in what I have found is that I get a more consistent result if I shut down CNC12 if I run a differnt job. If I don't it almost seems like part or all of the current job is still in memory? Not sure that makes sense or not?
You shouldn't need to shut down CCN12 when switching jobs, but if you've found a process that works for you that's great!
Greg
Post by Greg »
Hello new here with my first conversion and found your thread because I was having the EXACT same issues as you. Everything seemed to be working fine for a few parts until I crashed a $60 tool straight into some aluminum. After reading through all the pages I started thinking it was just lost motion and slowed down my Z rapids alot and slowed acceleration. I also reset my offsets after and found they were wrong due to lost motion. I ran the same gcode and it worked perfectly. I will do some further testing soon.Good luck
~edit~ I did more testing and the Z axis still falls short of home position only after running a program :oops: , machine coordinates say Z 0 when its about -.5
Make sure you tell the control which tool you are using to set the Z part zero.
Make sure your tool offsets are correct.
Greg wrote: Wed Feb 03, 2021 11:24 pm Hello new here with my first conversion and found your thread because I was having the EXACT same issues as you. Everything seemed to be working fine for a few parts until I crashed a $60 tool straight into some aluminum. After reading through all the pages I started thinking it was just lost motion and slowed down my Z rapids alot and slowed acceleration. I also reset my offsets after and found they were wrong due to lost motion. I ran the same gcode and it worked perfectly. I will do some further testing soon.Good luck
have you confirmed that you have the turns ratio set correctly?
Greg, start a new thread and follow this post: viewtopic.php?f=20&t=383
Good information provided will get you better suggestions for help.
