ATC Macro / PLC Help please <success!>
hebs
CNC Control System Serial Number: A81087B53034-0710192235
Re: ATC Macro / PLC Help please <success!>
Post by hebs »
Post deleted and new thread started (didn’t want to hijack this thread).
luchito1973
Post by luchito1973 »
Centroid_Tech wrote: Wed Jun 13, 2018 2:51 pm Unfortunately, there isn't. The only way around this issue that I can think of is the way that you have already determined using the M0.
hello, how i can resolve this problem.
I need controlling the turret without stops.
you have some idea?
Thanks in advanced.
luis Vega.
luchito1973 wrote: Tue Mar 03, 2020 10:52 am
you have some idea?
Thanks in advanced.
luis Vega.
Luis, without providing more information about your machine, your turret, how it operates, we won't be able to give you much advice.
Post pictures, of the turret, is it something you made or something that was made by the manufacturer of the lathe, how does it work etc
Start a NEW thread for yourself. From the main Acorn page, click on NEW TOPIC
luchito1973
And here is the code we are using. Running this via MDI always 'resets' the distance to go to 0 for the A Axis. Running it in a program, does not, so the calcs do not remain consistent. M0 in the code, or in the macro, solves the issue but the machine will wait for cycle start on tool change.
; Filename: cnctch.mac
; Description: Axis driven tool change macro for lathe
; Notes: Turns/rev must be configured 1 = 1 turret position change
; Turret is on 3rd axis, positions are in machine position.
; Requires: Machine home must be set prior to use.
;#100 = 8 ;Number turret positions
;#101 = ;Calculated position to move to when requested position < current position.
;#4120 = requested tool
;#20601-#20604 = Counts per unit for axes1-4
;#5021-#5024 is the current machine position for axes 1(#5021) through 4(#5024)
;follow with a block that skips if graphing or searching
IF #50001 ;Prevent lookahead from parsing past here
;If not searching or graphing, check to make sure the turret is not already
;at the requested position. If it is, skip the macro
IF [ABS[#4120-#5023] < .002] THEN GOTO 1000
;#4120 = requested turret position from g code
IF #5023 > #4120 THEN #101 = [6 + #4120] ELSE #101 = #4120
G53 A[#101 + 0.5]
G53 A[#101 - 0.5]
M0
M26 /A L[#4120*#20603]
N1000 ;Macro finished
luchito1973
atc turret axis driven fail
report_3403DE6E9763-0724192320_2020-03-07_09-19-14.zip
(281.76 KiB) Downloaded 147 times
Hi
Can anyone tell me if a solution to the "distance to go" issue as described in this thread and above has been found, other than to add an M0 in the code ?
I'm trying to get a home built ATC working with this macro and found this thread after hitting the exact same problem , everything works fine with tool commands from the MDI but when i run intercon generated code with multiple tools it falls over.
This is the code.
Thank you very much if anyone can help me.
; Description: Axis driven tool change macro for Lathe
; Turret is on 4th axis, positions are in machine position.
;#100 = 6 Number turret positions
;#101 = Calculated position to move to when requested position < current position.
IF [ABS[#4120-#5024] < .002] THEN GOTO 1000
IF #5024 > #4120 THEN #101 = [6 + #4120] ELSE #101 = #4120
G53 A[#101 + 0.2]
G53 A[#101 - 0.0]
M26 /A L[#4120*#20604]
M0 ; if I remove M0 it only works in MIDI.
Appears this issue has been resolved. See this POST from Allin1Chris: viewtopic.php?f=60&t=4133&p=33178#p33275
