12-4-24 v5.22 has been released, beta period for v5.22 is over.
Re: 12-4-24 v5.22 has been released, beta period for v5.22 is over.
Small hopefully only cosmetic bug in Acorn Six with encoder expansion board.
It shows counts/inch on a metric system for the expansion encoder ports in the wizard.
An I am still wondering if counts/deg will also work on a rotary axis ;)
report_0008DC111213-1113240211_2025-01-14_20-17-35.zip
(1.35 MiB) Downloaded 29 times
biobrett
CNC Control System Serial Number: Not Shown
Post by biobrett »
ASPeters wrote: Tue Jan 14, 2025 3:35 pm
biobrett wrote: Tue Jan 14, 2025 2:26 pm I'm not sure if this is related to a previous bug.
When setting the part z zero with tool x, height offset for tool 0 is used.
In the photo, you can see that t5 was used but H0 is shown for the tool height.
In your tool library, which Height offset is set to tool 5?
Can you post a report?
The tool height for T5 is not zero, it is something like 2.4" and is set relative to the probe (tool 1) which is used as the reference tool.
I have added a report from today to aid in diagnosing.
report_0008DC111213-0127222726_2025-01-15_15-20-36.zip
(4.79 MiB) Downloaded 24 times
biobrett
Post by biobrett »
Looking through the logs the Height for T5 is H000. I guess I missed that. I didn't even know that is possible to set a different height reference. My bad. What is the purpose of that? If I set a height for Tx, in the tool offset screen I would assume that Hx is set in the table.
I can have multiple offsets for one tool. Say i want to finish 0.005" deeper than i roughed. There are multiple ways to do this, but one of the easiest is just to use a tool height offset that's 0.005" different and rerun the existing code. Rough with T5 and H5, and finish with T5 and H105.
suntravel wrote: Tue Jan 14, 2025 3:51 pm Small hopefully only cosmetic bug in Acorn Six with encoder expansion board.
I can confirm that this is only cosmetic, mm input is ok on a metric system.
But the Wizard will not allow negative values for the encoder ports 1-3, scale setup in CNC12 will do.
In 5.20 lathe it was ok.
ASPeters
Post by ASPeters »
suntravel wrote: Sat Jan 18, 2025 2:02 pm
The cosmetic error was fixed in the most recent beta posted.
The deadband is the only value on the scales page that is not allowed to be negative. This is consistent with the settings in CNC12. Everything else should be fair game and seems to write to CNC12 correctly. Which textbox/menu are you having trouble with?
Counts/mm was not accepting -1000.
But in 5.23 it is ok again
suntravel wrote: Mon Jan 20, 2025 11:35 am Counts/mm was not accepting -1000.
thanks for reporting back.
