I've moved back to the Z: axis this morning. I noticed that the servo controller was intermittently coming up with an error (Er015). This is a maximum current error from the servo drive, which means that I am exceeding its maximum capacity. I confirmed this by looking at parameter Fn-03 on the servo drive.
Fn-03 displays a percentage of capacity of the drive, while the axis is moving.
When I moved the knee upwards Fn-03 showed that I was using 99% of the servo drive's capacity.
I have a few options here:
1/ Get a more powerful servo drive / motor.
2/ Stop trying to move the knee by CNC and change to moving the quill instead.
3/ Alter the pulley / motor ratio on the knee and proceed with the current setup.
The knee uses a system with a small toothed pulley on the servo motor and a larger pulley that drives the knee. the large pulley is currently 70mm in diameter and the small toothed pulley is around 48mm. I have a 90mm pulley spare, so I was thinking that this might be enough to reduce the effort for the motor to move the knee.
What do you think?
