Thc non plasma usage
Moderators: cnckeith, Joey
Joey
Plasma/Laser Lead
Re: Thc non plasma usage
Post by Joey »
Tamarbarr wrote: Thu Jul 20, 2023 3:59 pm Joey I need a different cnc12 plasma profile that will have different input configuration and also different motors configuration.
Is it possible?
It is not possible. Best way would be to set up a build for each. And rename the cncm folder to switch between both builds.
Tamarbarr
Post by Tamarbarr »
Hey there .
I'm posting all the progress I made on the fiber laser integrated sheet and tube cutter.
I've downloaded the new cnc12 version 5.06
The rotary axis with THC ON the Z axis still losing its position unfortunately that problem still isn't resolved.
Here is the report from the new cnc12 version 5.06
Here is the latest sheetcam plasma rotary post processor
PlasmaRotary Centroid V7.zip
(2.42 KiB) Downloaded 14 times
Here is a short program that I've made using the latest sheetcam plasma rotary post processor.
4040mm square tube 100mm long.
4040 NEW LASER 9.zip
(8.38 KiB) Downloaded 11 times
Here are couple of photos and videos of the fiber laser cutter.
https://drive.google.com/drive/folders/ ... b28enhjySA
Tamarbarr
Post by Tamarbarr »
Hey joey, I I'm having trouble with the rotary plasma.
The problem is that it can't recut.
For example if I have a torch collision for some reason I can't start the program again.
Is there a way to fix it?
