Page 8 of 14
Re: Shopbot PRS 48x96 Acorn / Clearpath Conversion
Posted: Tue Sep 15, 2020 4:51 pm
by paulwall
I knew they'd be pricey, but this I wasn't expecting.
Would it be the end of the world if I ran 3/8" face-width spurs on my 0.50" width racks?
Posted: Tue Sep 15, 2020 8:14 pm
by Gary Campbell
You can always give it a try, but the reality is that SB found they wouldn't hold up to the torque of their old PK series motors. Your ClearPath motors have 10 times the torque
Posted: Tue Sep 15, 2020 9:37 pm
by tblough
https://www.ebay.com/itm/InvolGearCuttr ... ect=mobile
Image shows #7, but the description says #6 which is what you need.
Posted: Wed Sep 16, 2020 1:47 am
by carbuthn
Tom,
Would he need a #6 (with a range of 17 to 20 teeth) or a #5 (with a range of 21 to 25 teeth)?
The only gears I have made was with a home-made fly cutter.
Just checking (and hoping to learn something).
Chuck
Posted: Wed Sep 16, 2020 5:46 am
by tblough
Chuck, you are correct. For some reason I was thinking he needed a 20 tooth gear!
Posted: Wed Sep 16, 2020 12:54 pm
by paulwall
I think I'm going to pursue the pinion gear stock option and have it machined into hopefully what I need and a few extras.
To keep costs down, is there any harm in running a the same 25 or 30 tooth gear on all axis's? SB used a 20 gear on Z, but I've got the bigger 3421S motor there so torque shouldn't be a problem.
I assume larger gears = longer gear service life, is that about right?
Posted: Wed Sep 16, 2020 1:49 pm
by tblough
Larger gears = load spread over more teeth but also higher torque.
Posted: Wed Sep 16, 2020 2:05 pm
by Gary Campbell
Paul...
To an extent that is correct. The hardness of the gears and rack, and lubrication will also play a factor. The larger the gear the less torque is available from a given motor.
The real answer is that you need to adjust your belt/gear reduction and pinion pitch diameter to achieve the desired resolution and keep the motor in its desired RPM/torque range. Use that combo to determine which torque/RPM range motor that best fits the overall design.
It would be my opinion that, yes, the Z axis would benefit from a smaller pinion (more reduction) as it always fights both gravity and inertia and operates at slower speeds than X and Y.
Posted: Wed Sep 16, 2020 2:43 pm
by paulwall
Gary Campbell wrote: Wed Sep 16, 2020 2:05 pm
I suppose that's the trouble with lack of 0.5" face spur gear availability.
Gary - Can I ask how you handle this recommendation for customers of yours who upgrade to your conversion kits?
Posted: Wed Sep 16, 2020 3:15 pm
by Gary Campbell
Paul...
Depending on the application & model, I use a combination of 3 ClearPath models, 5:1 or 10:1 gearboxes, and 18,20, 24, 25 & 30T pinions to get the output to match the machine's weight, desired speed and have more than adequate torque. I try not to provide upgrades for the old PRT's with the 14.5* PA rack, only the 1/2" wide 20* PA. Even then its hard not to over torque the frame as they use a spring loaded spur to rack engagement.
I have conceded to only putting NEMA23's on PRT models
