Oh, you will once you see how complex the WinCNC system is. I'm sure it works great and they have many users but after using the Acorn system for several years now and many retrofits under my belt I see the WinCNC design as an overly complex design with a lot of failure points. Not to mention it seems archaic for todays standards with PCI cards in your PC.slodat wrote: ↑Tue Dec 14, 2021 4:37 pmI have a Sidekick 8 still in the build process. Should be here mid January. I am already sure I will want to replace WinCNC.
Keith- maybe Shop Sabre will use your control!?
I'm really amazed at how simple the Acorn setup, programming and hardware is that seeing other systems REALLY makes me appreciate what Centroid has done. I must have pulled out about 10 pounds of junk from the ShopSabre control box and PC. Hopefully there's a sucker lurking on eBay looking for this stuff.
