ATC Macro / PLC Help please <success!>
luchito1973
Re: ATC Macro / PLC Help please <success!>
Post by luchito1973 »
With mach3 it is very easy to do it. with acorn I do not know how to do it, no I found a centroid macro reference.
DannyB
CNC Control System Serial Number: A900712
Post by DannyB »
Have you seen the PLC, Macro, and Skinning guide?
http://www.centroidcnc.com/centroid_diy ... manual.pdf
zigzagwanderer
CNC Control System Serial Number: A81087B9C645-0703192228
Post by zigzagwanderer »
Chaz wrote: Mon Jun 11, 2018 5:09 pm
Centroid_Tech wrote: Mon Jun 11, 2018 10:11 am Please post a current report from your system. You should not need to "unwind" a turret axis. Performing a tool change in MDI should be exactly the same as when running it from a program. Please also provide a copy of the program that you are running.
And here is the code we are using. Running this via MDI always 'resets' the distance to go to 0 for the A Axis. Running it in a program, does not, so the calcs do not remain consistent. M0 in the code, or in the macro, solves the issue but the machine will wait for cycle start on tool change.
; Filename: cnctch.mac
; Description: Axis driven tool change macro for lathe
; Notes: Turns/rev must be configured 1 = 1 turret position change
; Turret is on 3rd axis, positions are in machine position.
; Requires: Machine home must be set prior to use.
;#100 = 8 ;Number turret positions
;#101 = ;Calculated position to move to when requested position < current position.
;#4120 = requested tool
;#20601-#20604 = Counts per unit for axes1-4
;#5021-#5024 is the current machine position for axes 1(#5021) through 4(#5024)
follow with a block that skips if graphing or searching
IF #50001 ;Prevent lookahead from parsing past here
If not searching or graphing, check to make sure the turret is not already
at the requested position. If it is, skip the macro
IF [ABS[#4120-#5023] < .002] THEN GOTO 1000
;#4120 = requested turret position from g code
IF #5023 > #4120 THEN #101 = [8 + #4120] ELSE #101 = #4120
G53 A[#101 + 0.5]
G53 A[#101 - 0.5]
M26 /A L[#4120*#20603]
N1000 ;Macro finished
Hi
Can anyone tell me if a solution to the "distance to go" issue as described in this thread and above has been found, other than to add an M0 in the code ?
I'm trying to get a home built ATC working with this macro and found this thread after hitting the exact same problem , everything works fine with tool commands from the MDI but when i run intercon generated code with multiple tools it falls over.
Chaz
Post by Chaz »
zigzagwanderer wrote: Sun Aug 25, 2019 8:13 pm
G53 A[#101 + 0.5]
G53 A[#101 - 0.5]
Hi
Sorry, cant help - I no longer run an ATC on my lathe - but would be interested to know too.
zigzagwanderer
[/quote]
Hi
No problem and thanks for your reply.
With a little head scratching I modified the macro to better suit my application and so far it now works.
Chaz
Post by Chaz »
zigzagwanderer wrote: Wed Aug 28, 2019 8:43 am Sorry, cant help - I no longer run an ATC on my lathe - but would be interested to know too.
Hi
[/quote]
Can you please post the updated code? I have a friend (guy who makes these turrets) looking to implement one on his lathe.
thanks
fyi... Introduction to Centroid Macro's guide is here...
https://www.centroidcnc.com/centroid_di ... amming.pdf
Chaz
Post by Chaz »
cnckeith wrote: Fri Dec 27, 2019 1:32 pm fyi... Introduction to Centroid Macro's guide is here...
Nope, checking, thanks.
zigzagwanderer
Chaz wrote: Fri Dec 27, 2019 1:21 pm
Hi
thanks
[/quote]
I'm not sure how helpful it will be if your using a ratchet and pawl type ATC as mine is unidirectional and uses a hirth style coupling but have a look at this thread , as you will read i'm pretty green to all this but if i can supply any other info let me know
viewtopic.php?f=60&t=3616
Chaz
Post by Chaz »
All good thanks, just wanted to see how you solved it. Dont need the code as such and its helpful to others.
