Umbrella ATC - Acorn Compatible
Greg
Re: Umbrella ATC - Acorn Compatible
Post by Greg »
Yeah, the stars definitely have to align for TTS holders, but once it's dialed in, I haven’t had to mess with it again. Overall, it wasn’t too bad — just took a bit of patience.
Just the macro and made about four changes to the PLC to get everything working right. I’m still running V4.8, so I know things have changed a lot since then. I’m using a stepper motor with a Gecko driver for the Geneva mechanism — I did get help from the forum some really smart people here.
I’m not totally sure about the copper side — I’m pretty sure you can find fittings that go from 1/4" PU to copper, or worst case, you can just make an adapter.
I am using these kind of couplings:
https://www.esska-tech.co.uk/shop/T-com ... xxxx-10220
1/8 ID push in for the PU tube
https://www.esska-tech.co.uk/shop/Push- ... 2xxxx-6080
RJS100
Post by RJS100 »
Thanks Greg. I am using a similar pulse generator and Nema 23 stepper. I am wiring and bench testing now and looking forward to getting finished up. Thanks again for your thoughts. If you have any other images you have, I would love to see them.
Yes, there are lots of helpful folks on this forum. Uwe suggested machining the Geneva cam from Delrin and I think it was a great idea. When the cam is locked into position, there is absolutely no measurable play at all.
Uwe, thanks for the links to the compression couplings. Man... you are a fountain of knowledge!
Thanks... Richard
RJS100
Post by RJS100 »
Most of my ATC is done! All that's left is a few sensor mounting brackets.
Here is a video of it rotating. The Delrin cam (suggested by Uwe) is working great:
https://www.dropbox.com/scl/fi/rrjvy648 ... lh21m&dl=0
Before I mount it on the mill, I would like to do as much bench testing as possible. Can you guys recommend any gcode I can enter in MDI mode to help test the operation?
Best... Richard
