Retrofit My Build Looking at Switching from Mach4 to Centroid System
Re: Retrofit My Build Looking at Switching from Mach4 to Centroid System
Mechanical switches ALWAYS work.
Mechanical switches? What's that?
E415F6F70BC3-0318203049
I use Euchner mechanical (Jeez, I nearly typed Eunuch
Hope this helps
Nigel
Nigel
1 user liked this post
The good mechanical stuff:
https://www.balluff.com/en-us/products/BNS0008
but they are 200 bucks.
- CNC Control System Serial Number: 0008DC111213-0116240167
Thank you everybody. I had no idea I would be reinventing the wheel by using these optical switches. I used them on Mach 3 and Mach 4 and two different control boards with no issues so I figure I had to be doing something wrong.
I have a couple Balluff and Euchner in a box collecting dust.suntravel wrote: ↑Tue Nov 26, 2024 2:17 pm The good mechanical stuff:
Shawn - send them to me. I'm happy to help you clear out some of your junk.
Since I was dealing with the limit switches I hadn't messed around with the spindle and VFD yet. I'm waiting on the new sensors to arrive so I was looking at the VFD and spindle today.
I am able to get the VFD to "click" when I activate the spindle in CNC12 and change the speed shown on the readout of the VFD but the spindle does not turn on in either direction.
I do have 24v across the COM and 24V terminal so I connected the wiring as suggested back a few pages. I also reprogrammed the VFD.
I am suspecting it not actually turning on the spindle may have to do with all the issues I was having using the estop and trying to use a contactor and my general idiocrasy when it comes to electricity. I was able to get my servos working great once I removed all estop type connections but I did not make any changes to the way the spindle setup was done per the schematic.
I am planning on having a buddy that does motor control panels come over and help me do the contactors and estops correctly sometime in the next week but in the meantime how would I wire the AcornSIX for the spindle to work without the estop stuff mixed in so I can see if that's my issue.
Cut the contactor out of the wiring on S15158 - put the VFD enable signal directly between the Acorn output relay and the VFD input.
Just make sure you remember you did that and bring the E-stop back in when you figure out the issues
So I'm basically running a jumper from the middle connection on Out5 to the bottom connection on Out4?centroid467 wrote: ↑Tue Dec 03, 2024 10:02 am Cut the contactor out of the wiring on S15158 - put the VFD enable signal directly between the Acorn output relay and the VFD input.
Just make sure you remember you did that and bring the E-stop back in when you figure out the issues![]()
