New Build LMS 3990 Hi Torque Mini Mill
- CNC Control System Serial Number: 20D77886DD3D-0112247834
Limit Switches
Hey guys, I'm looking for some limit switch suggestions.
E415F6F70BC3-0318203049
Re: New Build LMS 3990 Hi Torque Mini Mill
Euchner mechanical specifically N01K550-M which I use on both Mill and Lathe. This has a tip accuracy of 30 microns for the ball tip variant or 20 microns if you prefer the chisel tip. More importantly, the repeatability is excellent and I have had no problem using Home for tool-setting
They also have a protection rating of IP67
See attached PDF page 30 for full technical details
- Euchner Limit and Position switches.pdf
- (4.04 MiB) Downloaded 4 times
Hope this helps
Nigel
Nigel
Not sure what you mean here...What am I missing?
if you have a bad switch or one not hooked up yet, you can override the input using the PLC diagnostic menu to "clear" it , if you need to do other things before fixing the switch. just be sure to go back and fix the switch and return the input to the normal state.
I'm looking to replace the crappy limit switches that came with the upgrade. I use flood coolant so I'm assuming I'll need Sealed (budget/decent) Switches. I also think a "plunger" style is best.cnckeith wrote: ↑Wed Jun 19, 2024 10:27 am if you have a bad switch or one not hooked up yet, you can override the input using the PLC diagnostic menu to "clear" it , if you need to do other things before fixing the switch. just be sure to go back and fix the switch and return the input to the normal state.
Your thoughts?
On multiple machines, I've never had problems with Euchner plunger switches, series SN:
https://www.euchner.de/en-us/products/p ... switch-sn/
I use the dual plunger versions:
https://avtechmachine.com/store/E08E12D11.html
Were you looking for decent or budget switches? Those two terms are exclusive.
1 user liked this post
These Euchners are top notch, I have them on conventional controlled machines running on oil cooling switching every few seconds for years with no problems.
Re: New Build LMS 3990 Hi Torque Mini Mill Cannot Adjust Turns Ratio
Hey folks. No matter how many times I go through the process of "adjusting overall turns ratio" in Y axis it stays off. I repeat the process to measure/verify the actual distance using 1-2-3 block(s) and the number is 0.002-0.005 off from correct.
Anyone have a suggestion of what to check next?
Adjusting the turns ratio cannot correct for poor mechanicals. Loose belts, poorly meshing gears/racks, slipping couplings, sloppy gibs, loose bearings, loose ways or guide rails, or sloppy gear reducers will all affect repeatability.
