Posts: 3650 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Fri May 10, 2024 9:35 am
That is because the conture is not closed, not all points are connected.
Filardo
Posts: 253 Joined: Wed Jul 28, 2021 3:54 am
Post
by Filardo » Fri May 10, 2024 9:41 am
suntravel wrote: ↑ Fri May 10, 2024 9:35 am
however if I look with Qcad no problem and when I select the contour on intercom too
Filardo
Post
by Filardo » Fri May 10, 2024 10:28 am
can you try with these new elements?
pochemarthyremanche.cnc
(7.51 KiB) Downloaded 17 times
contourmanche_telecaster.dxf
(19.92 KiB) Downloaded 13 times
Filardo
Post
by Filardo » Sat May 11, 2024 5:22 am
I succeeded with the cnc12 v5.1 Offline Mill and mill Intercon except that my parameters were in inches once I changed to millimeters it no longer works
j'ai réussi avec le cnc12 v5.1 Offline Mill and mill Intercon sauf que mes paramètres était en pouce une fois passer en millimètre ca ne fonctionne plus
Filardo
Post
by Filardo » Sat May 11, 2024 5:26 am
normally a dxf option is made to save time I use it every day when I work on itnc 530 never have so many problems
Post
by suntravel » Mon May 13, 2024 1:03 pm
I have no problems with dxf import, but this one is also not a closed contour.
To mill pockets, dxf must be closed around the pocket.
I use AutoCAD LT or Inkscape with no problems.
Filardo
Post
by Filardo » Tue May 14, 2024 12:13 am
suntravel wrote: ↑ Mon May 13, 2024 1:03 pm
I redid my dxf the outline it selects in one go without problem but it does not want to be interior
I just want to know how to do it with the dxf
here is attached my dxf in outline close can you try
j'ai refait mon dxf le contour ce sélectionne en une fois sans problème mais il ne veut pas faire intérieure
je veut juste savoir comment faire avec le dxf
voici en pièce jointe mon dxf en contour fermer pouvez vous essayer
jbf.cnc
(4.5 KiB) Downloaded 10 times
(99.61 KiB) Downloaded 12 times
Filardo
Post
by Filardo » Tue May 14, 2024 12:17 am
this is what I want to create with the dxf
voila ce que je veut créer avec le dxf
Post
by suntravel » Tue May 14, 2024 6:46 am
Why do you want to import dxf if you have the model in fusion?
Postprocessor for Centroid in fusion is very good.
Filardo
Post
by Filardo » Tue May 14, 2024 7:02 am
suntravel wrote: ↑ Tue May 14, 2024 6:46 am
Mon but est d'utiliser un maximum intercom
C'est tellement simple d'utilisation
Imaginons que ma poche est trop petite
En deux temps trois mouvements j'ai modifié mes cotations
Et si j'ai pris cette carte cnc c'était pour option dxf
Je voudrais tellement que cela fonctionne
Pouvez vous regarder le fichier que je viens de poster ce matin
Je comprends pas où est erreur
