Version 4.14 - Issues to Report, Please post them here
Re: Version 4.14 - Issues to Report, Please post them here
bruce, hello! you need to read this.. :D
viewtopic.php?f=63&t=1801
Racedirector
Post by Racedirector »
cnckeith wrote: Fri Mar 22, 2019 12:45 pm bruce, hello! you need to read this..
OK, I deserved that......
Some time today I will restart from scratch, just like I first got everything. I will do everything I need to do to get at least Y axis to move and will measure how far it goes under various settings to get things right....
Cheers
Bruce
Muzzer
Post by Muzzer »
Marty - you asked me to post the report for the 4.14 install that was crashing with my M3 macro. I've attached it here and checked that it had my modified M3 macro. As I said, it killed the CNC12 program totally and dumped me back on the desktop when trying to start the spindle initially in low range but with a high set speed, which would require the macro to change back to high ratio. Replacing it with the default M3 macro has my 4.14 installation running sweet.
report_38D269594F9C-0110180512_2019-03-22_15-05-54.zip
(231.31 KiB) Downloaded 133 times
Murray
Muzzer wrote: Sat Mar 23, 2019 6:27 pm Marty - you asked me to post the report for the 4.14 install that was crashing with my M3 macro. I've attached it here and checked that it had my modified M3 macro. As I said, it killed the CNC12 program totally and dumped me back on the desktop when trying to start the spindle initially in low range but with a high set speed, which would require the macro to change back to high ratio. Replacing it with the default M3 macro has my 4.14 installation running sweet.
Murray
I loaded and ran your M3 and indeed it crashed CNC12. 4.14. You say the very same M3 or M4 works in 4.12 correct?
We'll look into it.
Muzzer
Post by Muzzer »
Yes, I tested this out thoroughly in 4.12 before doing the update to double check it was working, as Keith warned that existing macros might not work with 4.14. Auto range selection was working fine in 4.12. After the update, I copied the M3 macro across and that killed it every time.
Would be nice to get the auto range selection working again but it's not something I expect to need much. However, you probably want to understand how a macro is able to kill the program so finally in the middle of a program.
fredrik
Post by fredrik »
Just did the update to 4.14
And after when i tried and start the program the virtual control panel wont show.
I have rebooter several times, both acorn and cnc12. At the moment the setting are as the program comes.
I also tried loading a backup file with my setting, and that did not work either. But i can always do the settings manually.
I have checked so windows is not interfering and that shouldnt be the problem.
Any tips?
Gary Campbell
Post by Gary Campbell »
Have you read and followed this? viewtopic.php?f=60&t=2909
fredrik
Post by fredrik »
Gary Campbell wrote: Sun Mar 24, 2019 11:24 am Have you read and followed this? viewtopic.php?f=60&t=2909
Thank you! That did it.
Muzzer wrote: Sun Mar 24, 2019 7:24 am Yes, I tested this out thoroughly in 4.12 before doing the update to double check it was working, as Keith warned that existing macros might not work with 4.14. Auto range selection was working fine in 4.12. After the update, I copied the M3 macro across and that killed it every time.
Looking into it Muzzer
martyscncgarage wrote: Sun Mar 24, 2019 1:33 pm
please find the edited version of the custom "muzzer" M3 that works with v4.14
mfunc3_414.mac
(2.24 KiB) Downloaded 123 times
