Snap-On Phil wrote: ↑Tue Apr 15, 2025 8:13 am
Very nice. I have a Bridgeport Series 2 Interact 2. That I just did an Allin1DC on and very happy with it except for the lack of torque in reverse when trying rigid tapping my spindle stalls. Might need to switch out my variable speed pulley for a one speed setup I’m thinking.
The Interact 4 uses the VSD and motor so no variable drive of course, a bit different to yours. My older mill had the variable drive that was always changing speeds and messing about so I junked it, used taperlock 8M pulleys and an induction motor and VSD, never looked back from doing that conversion.
It's been a while since I updated as I've been away with work, but back in the workshop last weekend. Next job was to sort the drawbar and petal clamp to work. I ended up removing the whole drawbar assembly including the belleville washer stacks. The reason is the petal clamp will insert from the bottom of the spindle but springs out in the tool indent, then won't come back out that way. The only way out is to pull the whole assembly out from the top. Anyway, it turns out there are about 100 belleville washers all stacked in alternating ministacks of 4 washers. Unfortunately the pics I took of this contraption seem to have vanished off my phone
I threaded the drawbar down another 1/4" on the top and shortened it so I can have some adjustment as it was threadbound. To adjust the petal clamp heights there is an adaptor in the top of the drawbar with a 5/8" BSW female thread and a grub screw of the same thread. The drawbar screws in then you tighten down the 5/8" grubscrew onto the top of the drawbar thread to lock it in place. I didn't work that out until I'd taken the whole thing apart.
With the petal clamp height set with the springs relaxed I could fire the air-hydraulic booster to operate the drawbar cylinder, but it was not happy. Instead of moving the cylinder down and compressing the belleville washers it just emptied the contents of the booster onto the workshop floor. Time to take the booster out and see what is going on
