10-22-24 UPDATE! CNC12 v5.20 has been released Mill, Lathe, Router, Plasma is now available for public testing.
Gary Campbell
Re: 9-6-24 UPDATE! CNC12 v5.19 rev6 BETA Mill, Lathe, Router, Plasma is now available for public testing.
Post by Gary Campbell »
cnckeith wrote: Mon Sep 16, 2024 2:51 pm i always send them here.
https://www.autodesk.com/products/fusio ... made-easy/
and i need to continue to work on this document but at least it is a start that covers the basics
https://www.centroidcnc.com/centroid_di ... rement.pdf
So you think that you can retrain a 65-70 yr old woodworker that has been doing it the "wrong way" for close to 20 years? I'll go with my version as it's nothing like trying to push a rope.
Gary Campbell wrote: Mon Sep 16, 2024 4:01 pm
i agree, not trying to push, just leading to water.
Re: 9-18-24 UPDATE! CNC12 v5.19 rev8 BETA Mill, Lathe, Router, Plasma is now available for public testing.
September 18 Update.
CNC12 v5.19 Beta Rev 8 Mill, Lathe, Router, Plasma is now available for public testing!
here is the download link.
https://centroid-support.filemail.com/d/ksnpxbvtukoogel
Big thanks to Scott and Craig for all the recent testing feedback helping us put the final polish on v5.2
v5.19 rev8 build notes.
- VCP will trigger of any switch type buttons that are triggered by the plc (useful as indicators on the vcp)
- Utility menu updated to have html advert across all versions of CNC12
- Fixed bug where rapid feed linked state would not update the status window if triggered from the vcp
- Fixed bug where cycling through search history in run menu would move focus away from search bar
- Fixed bug where the wizard would always show KP1 as the selected probe
- Fixed bug where the simple plc diagnostic tool would not update the IO after closing the options menu
v5.19 rev 7 (note: rev 7 was not made public)
- Removed DSP and DP7 probe from wizard
- Run Menus rewritten in MenuBoss framework. This allows the toggle buttons to be clickable without the use of function keys.
- Fixed some typos in the Hickory Lathe VCP skins that referenced cncm instead of cnct
- Fixed merge issue from v5.18 to v5.19 where the laser on/off button in the laser set part zero menu in router would not toggle the laser off
- Fixed bug where "I will create my own home program" option would set the home type as Simple, thereby not running cncm/t.hom. Added the axis homing direction and order for this option as well.
- Fixed bug where Import IO Preset was not working
- New Hickory hex file for improved Leadshine EL7 Ethercat servo drive communication.
- Fixed a VCP Widgets Win11 bug
I have installed R8 on my lathe with Acorn6.
mfunc50.mac is missing
MPG on port 3 for Z axis is without function
VCP skin is not accepting a color in the skin, but a jpg for the background is ok
report_0008DC111213-0511220026_2024-09-21_13-00-02.zip
(1.06 MiB) Downloaded 5 times
I switched back to my previous Beta, because the spindle it turning in manual mode, but not with M3/4
M3/4 is not switching Output4, manual spindle start does it.
First OPCON USB is working, had to be configured like the USB BOB
Z axis can be moved with the WMPG, but not with the MPG
FRV is on by default
This is the first Beta I cannot use...
Sword
Post by Sword »
I too noticed that the previous background color option for the skin file didn't work with beta 6 & 7, but forgot to mention it. :(
The image background works great though. ;)
Scott
On my mill with Acorn no problems so far.
I like the changes in the Wizard.
USB BOB with WMPG together is now not so efficient with 4th axis.
WMPG must be on Feed/Speed to activate the MPGs on the BOB, so if I want to turn the 4th axis, WMPG to 100x
Use MPG on the BOB, WMPG to Feed, press MPGLED on the BOB
Last Version was if WMPG is on 4th Axis I could use all MPGs together, that is better IMHO.
I have made my own VCP background image with a 3D look.
report_6433DB0446C1-0811215047_2024-09-22_09-36-12.zip
(1.27 MiB) Downloaded 4 times
RogDC
Post by RogDC »
I noticed a change along the beta/RC's where the BOB MPG is disabled upon startup of CNC12 by default. So I added an MPG toggle to the buttons list.
I don't have a 4th axis to test.
Installed on my router without any functional issues so far.
thanks for the feedback, 8-) vcp solid color has been fixed and we are reviewing / investigating the rest of the comments. :D
Sword wrote: Sat Sep 21, 2024 2:56 pm I too noticed that the previous background color option for the skin file didn't work with beta 6 & 7, but forgot to mention it. :(
i really like that background! and the options and free/pin icon can i use them? please post a fresh report.zip so i have it.
