Page 7 of 8
Re: Denford Triac Carousel ATC
Posted: Sun Jun 30, 2024 11:17 pm
by Greg
Yes I redact that statement. A report would be helpful. I am no expert so I like to keep things simple. I still think a slightly modified macro should control this ATC easily.
Posted: Mon Jul 01, 2024 4:11 am
by Chaz
Ill get a report. The ATC is working but directly from the Main Board (its not 100% finished but functionally it works), not using the External Outputs as I cannot activate them (other than forced).
Posted: Mon Jul 01, 2024 5:48 am
by Chaz
Report attached. I can see in the .src file the outputs on Eth1616 are mapped.
Oddly the M6 file isnt correct but I have a backup (I use OUTPUT 5 etc onwards) as I'm struggling to address the Eth1616 Board.
Posted: Mon Jul 01, 2024 1:06 pm
by cncsnw
From the PLC source in your report:
; #wizardregion Outputs
SpinFWD                IS OUT1
Flood                  IS OUT2
OUTPUT3                IS OUT3
NoFaultOut             IS OUT4
OUTPUT5                IS OUT5
OUTPUT6                IS OUT6
OUTPUT7                IS OUT7
OUTPUT8                IS OUT8
ATC_CarouselIn         IS OUT33
ATC_CarouselOut        IS OUT34
ATC_CarouselForward    IS OUT35
UnclampTool            IS OUT37
; #endregion
M94M95114                    IS MEM389
M94M95112                    IS MEM389
M94M95113                    IS MEM389
M94M95116                    IS MEM389
M94M95117                    IS MEM389
M94M95118                    IS MEM389
M94M95119                    IS MEM389
M94M95120                    IS MEM389
M94M95121                    IS MEM389
M94M95122                    IS MEM389
M94M95123                    IS MEM389
M94M95124                    IS MEM389
M94M95125                    IS MEM389
M94M95126                    IS MEM389
M94M95111                    IS MEM389
M94M95115                    IS MEM389
As you can see, you do not have any of the "M94M951nn" tokens assigned to physical outputs. They are all "parked" on a memory bit, which in turn is not used for anything.
That is why, for example, "M94/117" does not change any output.
Posted: Tue Jul 02, 2024 2:15 am
by Chaz
cncsnw wrote: Mon Jul 01, 2024 1:06 pm From the PLC source in your report:
SpinFWD                IS OUT1
Flood                  IS OUT2
OUTPUT3                IS OUT3
NoFaultOut             IS OUT4
OUTPUT5                IS OUT5
OUTPUT6                IS OUT6
OUTPUT7                IS OUT7
OUTPUT8                IS OUT8
; #endregion
M94M95114                    IS MEM389
M94M95112                    IS MEM389
M94M95113                    IS MEM389
M94M95116                    IS MEM389
M94M95117                    IS MEM389
M94M95118                    IS MEM389
M94M95119                    IS MEM389
M94M95120                    IS MEM389
M94M95121                    IS MEM389
M94M95122                    IS MEM389
M94M95123                    IS MEM389
M94M95124                    IS MEM389
M94M95125                    IS MEM389
M94M95126                    IS MEM389
M94M95111                    IS MEM389
M94M95115                    IS MEM389
Thanks. So how does this get set? Do I need to edit the .src and recompile? I would have assumed once these are assigned in the Wizard, no further action would be needed? This works for the main output board, why not the Eth1616?
Posted: Wed Jul 03, 2024 9:34 am
Chaz wrote: Tue Jul 02, 2024 2:15 am
SpinFWD                IS OUT1
Flood                  IS OUT2
OUTPUT3                IS OUT3
NoFaultOut             IS OUT4
OUTPUT5                IS OUT5
OUTPUT6                IS OUT6
OUTPUT7                IS OUT7
OUTPUT8                IS OUT8
; #endregion
M94M95114                    IS MEM389
M94M95112                    IS MEM389
M94M95113                    IS MEM389
M94M95116                    IS MEM389
M94M95117                    IS MEM389
M94M95118                    IS MEM389
M94M95119                    IS MEM389
M94M95120                    IS MEM389
M94M95121                    IS MEM389
M94M95122                    IS MEM389
M94M95123                    IS MEM389
M94M95124                    IS MEM389
M94M95125                    IS MEM389
M94M95126                    IS MEM389
M94M95111                    IS MEM389
M94M95115                    IS MEM389
in the Wizard output menu under the "custom" drop down you can assign M94M95 to any output (ether1616 included)
Posted: Thu Jul 04, 2024 10:45 am
by Chaz
cnckeith wrote: Wed Jul 03, 2024 9:34 am
SpinFWD                IS OUT1
Flood                  IS OUT2
OUTPUT3                IS OUT3
NoFaultOut             IS OUT4
OUTPUT5                IS OUT5
OUTPUT6                IS OUT6
OUTPUT7                IS OUT7
OUTPUT8                IS OUT8
; #endregion
M94M95114                    IS MEM389
M94M95112                    IS MEM389
M94M95113                    IS MEM389
M94M95116                    IS MEM389
M94M95117                    IS MEM389
M94M95118                    IS MEM389
M94M95119                    IS MEM389
M94M95120                    IS MEM389
M94M95121                    IS MEM389
M94M95122                    IS MEM389
M94M95123                    IS MEM389
M94M95124                    IS MEM389
M94M95125                    IS MEM389
M94M95126                    IS MEM389
M94M95111                    IS MEM389
M94M95115                    IS MEM389
Thanks. Ill take a look at this later. Is this documented anywhere? So, for anyone needing to use Eth1616's outputs via M codes, would need to do this?
Posted: Thu Jul 04, 2024 3:47 pm
by cncsnw
See page 13:
https://www.centroidcnc.com/centroid_di ... s_v4.8.pdf
That page does not specifically mention the Ether1616, because those functions are not limited to the Ether1616 outputs; nor are any of the other functions prohibited from Ether1616 outputs. You put the functions you want on the outputs you want, using the Wizard.
Posted: Fri Jul 05, 2024 5:20 pm
by Chaz
cncsnw wrote: Thu Jul 04, 2024 3:47 pm See page 13:
Posted: Thu Aug 22, 2024 3:51 pm
by Chaz
I'm back on this machine to finish off the install as Ive needed to get the plates made and installed for the motor mounts.
Some really odd issues.
MPG is on, nothing on the screen.
The ATC macro doesnt work. Even running something like M94 /65 to switch on an output doesnt work (in the macro or via MDI). *NEVERMIND* - fixed, back to the OUTPUT definitions ....
However it looks like the MPG has died. Has anyone seen one where the screen illuminates however there is no text and it doesnt respond to any buttons etc?
