New Build LMS 3990 Hi Torque Mini Mill
cdiseker
CNC Control System Serial Number: 20D77886DD3D-0112247834
Re: New Build LMS 3990 Hi Torque Mini Mill
Post by cdiseker »
Suntravel, Thanks so much! I'm out to the shop this morning to setup the tool library, etc. in CNC12 then doing a test run.
cdiseker
Start program after a tool change
Post by cdiseker »
I need to repeat a tool path drilling some holes. Seems my too offset was off and the drill bit did no go down far enough. How can I start from tool 4 in this case?
F4 Run, F2 search
cdiseker
Post by cdiseker »
Thanks.
cdiseker
Delete Current Job
Post by cdiseker »
Is it possible to delete a current job in CNC12?
As I update my model in Fusion360 and run it again I'd rather not have multiple file names for the same job but edit in Fusion and save it as current.
If the new job with same name is placed in the same location as the current job, CNC12 will execute the new job.
cdiseker
Post by cdiseker »
So, just load the new job file and Cycle Start?
If 1111.nc is loaded and you replace this file with a new version 1111.nc just hit cycle start.
No need to load it again.
cdiseker
Post by cdiseker »
Okay, thanks.
cdiseker
How to Find Part Zero
Post by cdiseker »
I've loaded my file into Acorn and I've used the Probe to find Part Zero per instructions several times today. When I hit Cycle Start the cutter always travels an inch to far in the -Y and is not close to the part. The tool path in the graph looks correct, the depth looks correct, the X looks correct...not Y.
Any ideas on where to look next? Could it be a machine or parameter setting?
