ATRUMP E216 Mill Conversion
Re: ATRUMP E216 Mill Conversion
So it WAS working fine and now it is not?
Jqmce
CNC Control System Serial Number: A900979
Post by Jqmce »
Here is the Video:
I should also add that the draw bar does start to release but stops as soon as the spindle turns.
when fault happens spindle turns at VFD speed 6.9%
Jqmce
Post by Jqmce »
That's correct Marty. was working and now it is not.
Take a look at your error logs
F7 Utility F9 Logs F1 Errors
I see some Tool Unclamp Faults among others:
(1) 03-18-2022 12:01:48 199 CNC Started
(1) 03-18-2022 12:02:54 102 Error initializing CPU...cannot continue.
(1) 03-18-2022 12:02:56 Exiting CNC due to unknown error (63)
(1) 03-18-2022 12:03:21 199 CNC Started
(1) 03-18-2022 12:05:24 199 CNC Started
(1) 03-18-2022 12:08:08 199 CNC Started
(1) 03-18-2022 12:08:12 CNC12-D Mill v4.18
(4) 03-18-2022 12:08:13 2099 Message Cleared
(1) 03-18-2022 12:08:32 Created Weekly Report
(1) 03-18-2022 12:08:44 407 Z+ limit (#50006) tripped
(1) 03-18-2022 12:09:14 407 X- limit (#50001) tripped
(1) 03-18-2022 12:09:31 407 Y+ limit (#50004) tripped
(4) 03-18-2022 12:10:41 907 X axis travel exceeded
(4) 03-18-2022 12:10:47 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:10:53 9090 Reset Cleared
(4) 03-18-2022 12:11:00 907 Y axis travel exceeded
(4) 03-18-2022 12:11:02 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:11:02 9090 Reset Cleared
(4) 03-18-2022 12:11:14 907 X axis travel exceeded
(4) 03-18-2022 12:11:18 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:11:18 9090 Reset Cleared
(1) 03-18-2022 12:13:21 Waiting for Spindle Orientation...
(1) 03-18-2022 12:13:25 Waiting for Carousel In...
(1) 03-18-2022 12:13:29 Waiting for Tool UnClamp...
(4) 03-18-2022 12:13:31 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 12:13:41 406 Emergency stop detected
(4) 03-18-2022 12:13:41 2099 Message Cleared
(4) 03-18-2022 12:14:14 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:14:15 9090 Reset Cleared
(1) 03-18-2022 12:14:47 Waiting for Spindle Orientation...
(1) 03-18-2022 12:14:53 Waiting for Tool UnClamp...
(4) 03-18-2022 12:14:54 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 12:15:08 406 Emergency stop detected
(4) 03-18-2022 12:15:09 2099 Message Cleared
(4) 03-18-2022 12:15:11 2099 Message Cleared
(1) 03-18-2022 12:15:31 406 Emergency stop detected
(4) 03-18-2022 12:17:53 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:17:54 9090 Reset Cleared
(1) 03-18-2022 12:20:22 199 CNC Started
(1) 03-18-2022 12:20:26 CNC12-D Mill v4.18
(4) 03-18-2022 12:20:27 2099 Message Cleared
(1) 03-18-2022 12:20:31 406 Emergency stop detected
(1) 03-18-2022 12:21:14 407 Z+ limit (#50006) tripped
(1) 03-18-2022 12:22:00 407 X- limit (#50001) tripped
(1) 03-18-2022 12:22:26 407 Y+ limit (#50004) tripped
(4) 03-18-2022 12:23:57 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:23:58 9090 Reset Cleared
(1) 03-18-2022 12:25:21 Waiting for Spindle Orientation...
(4) 03-18-2022 12:25:22 9056 ORIENT LOST FAULT
(4) 03-18-2022 12:25:38 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:25:39 9090 Reset Cleared
(1) 03-18-2022 12:26:12 Waiting for Spindle Orientation...
(1) 03-18-2022 12:26:16 Waiting for Carousel In...
(1) 03-18-2022 12:26:20 Waiting for Tool UnClamp...
(4) 03-18-2022 12:26:21 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 12:26:48 406 Emergency stop detected
(4) 03-18-2022 12:26:48 2099 Message Cleared
(4) 03-18-2022 12:26:49 2099 Message Cleared
(4) 03-18-2022 12:26:56 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:26:57 9090 Reset Cleared
(4) 03-18-2022 12:27:00 9091 Reset Initiated, Press Reset to Clear
(1) 03-18-2022 12:27:20 406 Emergency stop detected
(4) 03-18-2022 12:27:20 2099 Message Cleared
(4) 03-18-2022 12:30:00 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:30:00 9090 Reset Cleared
(4) 03-18-2022 12:30:02 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 12:30:02 9090 Reset Cleared
(1) 03-18-2022 13:50:58 406 Emergency stop detected
(4) 03-18-2022 13:50:58 2099 Message Cleared
(4) 03-18-2022 13:52:12 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 13:52:12 9090 Reset Cleared
(4) 03-18-2022 13:52:13 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 13:52:14 9090 Reset Cleared
(4) 03-18-2022 13:54:40 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 14:24:19 9090 Reset Cleared
(1) 03-18-2022 14:26:37 Waiting for Spindle Orientation...
(4) 03-18-2022 14:27:00 9056 ORIENT LOST FAULT
(4) 03-18-2022 14:27:03 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 14:27:04 9090 Reset Cleared
(1) 03-18-2022 14:27:16 Waiting for Spindle Orientation...
(1) 03-18-2022 14:27:32 Waiting for Tool UnClamp...
(1) 03-18-2022 14:28:35 Waiting for Tool UnClamp...
(1) 03-18-2022 14:29:02 503 Invalid M function
(4) 03-18-2022 14:29:15 503 Invalid M function
(1) 03-18-2022 14:30:40 Waiting for Carousel In...
(1) 03-18-2022 14:30:50 406 Emergency stop detected
(4) 03-18-2022 14:30:50 2099 Message Cleared
(4) 03-18-2022 14:31:02 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 14:31:03 9090 Reset Cleared
(1) 03-18-2022 14:31:25 Waiting for Carousel In...
(1) 03-18-2022 14:33:15 Waiting for Carousel In...
(1) 03-18-2022 14:34:50 Waiting for Spindle Orientation...
(1) 03-18-2022 14:34:53 Waiting for Carousel In...
(1) 03-18-2022 14:34:57 Waiting for Tool UnClamp...
(4) 03-18-2022 14:34:59 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 14:35:27 406 Emergency stop detected
(4) 03-18-2022 14:35:27 2099 Message Cleared
(4) 03-18-2022 14:35:30 2099 Message Cleared
(1) 03-18-2022 14:35:44 Waiting for Carousel Out...
(4) 03-18-2022 14:36:18 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 14:36:34 9090 Reset Cleared
(4) 03-18-2022 14:36:35 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 14:36:36 9090 Reset Cleared
(1) 03-18-2022 14:37:17 Waiting for Carousel Out...
(1) 03-18-2022 14:37:48 406 Emergency stop detected
(4) 03-18-2022 14:37:48 2099 Message Cleared
(1) 03-18-2022 14:39:18 Waiting for Carousel In...
(1) 03-18-2022 14:40:31 Waiting for Spindle Orientation...
(1) 03-18-2022 14:40:42 Waiting for Carousel In...
(1) 03-18-2022 14:41:31 406 Emergency stop detected
(4) 03-18-2022 14:41:31 9056 ORIENT LOST FAULT
(4) 03-18-2022 14:41:31 2099 Message Cleared
(1) 03-18-2022 15:02:45 2051 Manual Coolant Mode
(1) 03-18-2022 15:02:45 2050 Auto Coolant Mode
(1) 03-18-2022 15:05:25 Waiting for Spindle Orientation...
(1) 03-18-2022 15:05:29 Waiting for Carousel In...
(1) 03-18-2022 15:05:33 Waiting for Tool UnClamp...
(4) 03-18-2022 15:05:35 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 15:07:11 199 CNC Started
(1) 03-18-2022 15:07:14 CNC12-D Mill v4.18
(4) 03-18-2022 15:07:16 2099 Message Cleared
(1) 03-18-2022 15:07:58 407 Z+ limit (#50006) tripped
(1) 03-18-2022 15:08:37 407 X- limit (#50001) tripped
(1) 03-18-2022 15:09:03 407 Y+ limit (#50004) tripped
(1) 03-18-2022 15:27:44 Waiting for Spindle Orientation...
(1) 03-18-2022 15:27:47 Waiting for Carousel In...
(1) 03-18-2022 15:27:51 Waiting for Tool UnClamp...
(4) 03-18-2022 15:27:53 9055 TOOL CLAMP UNCLAMP FAULT
(4) 03-18-2022 15:28:24 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:28:24 9090 Reset Cleared
(1) 03-18-2022 15:28:37 Waiting for Spindle Orientation...
(1) 03-18-2022 15:28:40 Waiting for Carousel In...
(1) 03-18-2022 15:28:44 Waiting for Tool UnClamp...
(4) 03-18-2022 15:28:46 9055 TOOL CLAMP UNCLAMP FAULT
(1) 03-18-2022 15:28:46 Waiting for Tool UnClamp...
(4) 03-18-2022 15:30:05 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:30:06 9090 Reset Cleared
(1) 03-18-2022 15:30:25 Waiting for Spindle Orientation...
(1) 03-18-2022 15:30:29 Waiting for Carousel In...
(1) 03-18-2022 15:30:33 Waiting for Tool UnClamp...
(4) 03-18-2022 15:30:34 9055 TOOL CLAMP UNCLAMP FAULT
(4) 03-18-2022 15:30:50 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:30:52 9090 Reset Cleared
(4) 03-18-2022 15:32:40 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:32:42 9090 Reset Cleared
(1) 03-18-2022 15:33:00 Waiting for Spindle Orientation...
(1) 03-18-2022 15:33:04 Waiting for Carousel In...
(1) 03-18-2022 15:33:08 Waiting for Tool UnClamp...
(4) 03-18-2022 15:33:09 9055 TOOL CLAMP UNCLAMP FAULT
(4) 03-18-2022 15:35:25 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:35:25 9090 Reset Cleared
(1) 03-18-2022 15:35:39 Waiting for Spindle Orientation...
(1) 03-18-2022 15:35:43 Waiting for Carousel In...
(1) 03-18-2022 15:35:47 Waiting for Tool UnClamp...
(4) 03-18-2022 15:35:48 9055 TOOL CLAMP UNCLAMP FAULT
(4) 03-18-2022 15:36:00 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:36:02 9090 Reset Cleared
(1) 03-18-2022 15:37:49 406 Emergency stop detected
(4) 03-18-2022 15:37:50 2099 Message Cleared
(4) 03-18-2022 15:38:42 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:38:42 9090 Reset Cleared
(4) 03-18-2022 15:38:43 9090 Reset Cleared
(1) 03-18-2022 15:40:55 Waiting for Spindle Orientation...
(1) 03-18-2022 15:40:59 Waiting for Carousel In...
(1) 03-18-2022 15:41:03 Waiting for Tool UnClamp...
(1) 03-18-2022 15:41:03 406 Emergency stop detected
(4) 03-18-2022 15:41:03 2099 Message Cleared
(4) 03-18-2022 15:41:05 2099 Message Cleared
(1) 03-18-2022 15:44:15 Report installed from C:\cncm\reportbackup\report_0008DC111213-0127211089_2021-03-22_05-38-43.zip
(1) 03-18-2022 15:44:28 Exiting CNC and shutting down machine (68)
(1) 03-18-2022 15:45:47 199 CNC Started
(4) 03-18-2022 15:45:50 9039 Software Ready Fault
(1) 03-18-2022 15:45:51 CNC12-D Mill v4.18
(4) 03-18-2022 15:45:52 9039 Software Ready Fault
(4) 03-18-2022 15:46:09 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:46:10 9090 Reset Cleared
(1) 03-18-2022 15:46:40 407 Z+ limit (#50006) tripped
(1) 03-18-2022 15:46:46 407 X- limit (#50001) tripped
(1) 03-18-2022 15:46:55 407 Y+ limit (#50004) tripped
(1) 03-18-2022 15:47:38 Waiting for Spindle Orientation...
(1) 03-18-2022 15:47:42 Waiting for Carousel In...
(1) 03-18-2022 15:47:46 Waiting for Tool UnClamp...
(4) 03-18-2022 15:47:47 9055 TOOL CLAMP UNCLAMP FAULT
(4) 03-18-2022 15:47:53 9091 Reset Initiated, Press Reset to Clear
(4) 03-18-2022 15:47:54 9090 Reset Cleared
(1) 03-18-2022 15:49:30 Creating report...
(1) 03-18-2022 15:49:40 Saved report to C:\cncm\report_0008DC111213-0127211089_2022-03-18_15-49-30.zip
(1) 03-18-2022 15:50:36 Creating report...
Jqmce wrote: Fri Mar 18, 2022 7:45 pm Here is the Video:
Please upload the video to YouTube, mark it unlisted and SHARE a link here.
Jqmce
Post by Jqmce »
Thanks for the tip Marty.
Video at link below.
https://youtu.be/wQ4jMoR1ZTo
Jqmce wrote: Fri Mar 18, 2022 8:35 pm Thanks for the tip Marty.
I've asked Centroid to look at your report
I don't understand why the control is allowing the spindle to run with the ATC IN.
Irregardless of what the issue is.
I would be looking at the diagnostic screen and manually running the carousel IN and OUT and watch the inputs
I would also manually CLAMP and UNCLAMP the tool and watch the inputs to see if they are showing properly.
You do have an UNCLAMP fault you have to track down.....
Jqmce
Post by Jqmce »
Thanks Marty,
Manually clamp and unclamp work via MDI.
Manually I have never been able to move the carousel in and out via MDI / M80 M81. I’m using virtual control and the whole AUX12 thing has always alluded me. See previous post on this last year.
Jqmce
Post by Jqmce »
Agreed on Unclamp fault. I did manually test switches for clamp and unclamp by physically pushing roller switches. Inputs were coming on and off. Manual push of physical tool unlock button also works.
Have to do some more digging in on this.
