Acorn CNC12 v4.14 has been released.
Re: Acorn CNC12 v4.14 has been released.
wjh308 wrote: Fri Apr 05, 2019 11:22 pm So what is the biggest reason to have this new version? I do not like the fact it won't do the inch/mm conversion, that is a step backwards in my opinion. Heck, it's been so long since I've used my CNC mill, I feel like I have to relearn everything anyhow.
release notes are with the download, in case you missed them. here is the link. ( if your machine is running great and you don't see any features that interest you and you don't need support then no need to update. )
http://www.centroidcnc.com/centroid_diy ... _notes.pdf
i dont' see the big deal with entering metric values (mm) for a metric (mm) setup... as i explained in the "how to setup for metric (mm)" video.
and you can use Swissi's metric conversion work around method if you follow his instructions to the T, or you can just google "inch to mm"
