The attached DYN4 schematic works....qjones wrote: ↑Tue Mar 05, 2019 12:38 am Just when I thought I had gotten out of the Screw Terminals vs DB25 woods. I think I am having this issue to the more I think about a few random cuts that dropped a hair low. I blamed it on a possible tool offset being wrong. But in hindsight I don't think it was. I am not looking forward to having to pull my mill back out from the wall to get back to my electronics after I just leveled and calibrated it all finally.
2 questions:
1) If you remove/replace the resistor in the DMM Centroid cable SHOULD it still work on the screw terminal outputs?
2) Since the original schematics originally didn't indicate I would have to use the DB25 head my acorn board is mounted in a tight spot that I don't have much room to come off with a DB25 breakout. Does anyone know of a good right angled connector or breakout or cable to use in a tight space?
Another DYN4 and Acorn Losing Steps Issue
Re: Another DYN4 and Acorn Losing Steps Issue
I was losing encoder counts (steps between Acorn and DYN4) using that schematic. The thing that solved this was the DB25 step and direction signals.
Acorn powered CNC router
So since I already have the DMM DB25 cable I would still need to remove the resistor than connect to my +5v power supply? Which I am kicking myself because I kind of hated the voltage drop configuration anyway to the DMM considering I have a true +5v just sitting there waiting to be connected to.martyscncgarage wrote: ↑Tue Mar 05, 2019 9:33 am
S14888-ACORN_rev3 DMM DYN4 SERVO DRIVE.pdf
No resistor required if you follow the Centroid schematic.qjones wrote: ↑Tue Mar 05, 2019 11:34 amSo since I already have the DMM DB25 cable I would still need to remove the resistor than connect to my +5v power supply? Which I am kicking myself because I kind of hated the voltage drop configuration anyway to the DMM considering I have a true +5v just sitting there waiting to be connected to.martyscncgarage wrote: ↑Tue Mar 05, 2019 9:33 am
Use the 5vdc.
You could contact DMM and ask for the correct resistor value. They have made a change. See my post on the forum about this issue.
Milton in Collierville, TN
Again, I was losing steps between Acorn and DYN4 using 5v and the screw terminals.
viewtopic.php?f=60&t=2814&start=20#p20394
Respectfully, I understand you were having issues. I've not had those issues and it's worth allowing someone else the opportunity to check it out. If there is an issue, collectively it's worth all of us trying to replicate and subsequently solve the problem.slodat wrote: ↑Tue Mar 05, 2019 12:35 pm Again, I was losing steps between Acorn and DYN4 using 5v and the screw terminals.
You had the problem, but why?
I've been all over amazon looking. Never saw this one. It looks almost perfect for my needs.DICKEYBIRD wrote: ↑Tue Mar 05, 2019 12:07 pmI'm using this one:
https://www.amazon.com/Signals-Breakout ... 1-fkmrnull
Thanks!
I can't duplicate the problem when using my single DMM DYN4 750W servo. I'm using the DMM cable with the 2W resistor that Marty showed in a video a few months back. I am NOT using 5VDC. Everything is connected to the H2 connector, as instructed in the DMM wiring diagram that was sent to me when I purchased the drive, the motor and the necessary cables.
Just because I can't duplicate the problem does not mean that there is no problem, but at least on my test bench, everything is working as expected.
-Mike Richards
I agree. This is why I went to great lengths to perform the same test, changing one thing at a time until the problem went away. I test and troubleshoot for a living. As I have stated before, I was posting my results in hopes of helping the manufacturers, and others experiencing the same lost steps problem. While I do not know the cause, it is apparent the DYN4 works well with the DB25 step/direction signals on machines it has problems with the screw terminals. The why.. I don't know.martyscncgarage wrote: ↑Tue Mar 05, 2019 12:56 pm ... If there is an issue, collectively it's worth all of us trying to replicate and subsequently solve the problem.
Again, my intention is to contribute to this community.
