New Build, Acra Mill with Allin1DC, Videos and Photos <upgraded to DC servos>
Re: New Build, Acra Mill with Allin1DC, Videos and Photos <upgraded to DC servos>
The only current issue is that the electronic lube pump is a lube first version. It's over lubing the mill. As soon as I hit cycle start it turns on. So, that's not good if you stop and start often. The mill is dripping with oil. I don't think I can shorten the pump time. If It did a quick shot of oil at startup, it would probably be fine. Is there a solution for this situation??
Set Parameter 179 to 100x the number of minutes you want pump power to remain on, even if the cycle times are shorter.
For example, if you set P179 = 4000, then the lube output will remain on for a minimum of 40 minutes, rather than turning off as soon as the cycle is done. That will prevent multiple lube power-on events during that span.
