incorrect cutting in a pocket <cutter comp in control vs cutter comp in cad/cam>
Re: incorrect cutting in a pocket <cutter comp in control vs cutter comp in cad/cam>
Reposted with better image below.
28.351+6=34.351
You are measuring the distance between sharp corners and subtracting your cutter diameter thinking that is what your tool path dimension should be. That is not the case.
Post the fusion f3d file pls.
I tried Uwe, the board does not allow that extension?
Zip it...
or change file extension to pdf
thanks
- midi+tool(1).pdf
- (147.41 KiB) Downloaded 2 times
There are the missing ca. 0.5mm
Not a software fault, only wrong choice of tooling.
I wonder how they have been cutting to size all this time with a 6mm end mill, this doesn't make any sense lol
this pic is proving nothing.
If you do not want to accept geometrical laws, I give up explaining further.
It is a case of if the peasant can't swim it is the swimming trunk's fault
(a German saying)
