Page 5 of 8
Re: Thc non plasma usage
Posted: Fri May 05, 2023 3:04 pm
by Joey
Also a fresh report ASAP please! We're close to knocking this out.
Posted: Fri May 05, 2023 10:02 pm
by Joey
Tamar
Les will probably need to adjust his Post. I've communicated to Les how the B axis will be set.
How to set the rotary axis to linear axis for Sheetcam.
1. Set rotary as a linear axis
2. Move Rotary to Zero
3. Set DRO position to Zero
4. Jog Rotary table one revolution (360 degrees)
5.Read DRO position
6. Calculate adjusted mm per turn
Calculation for new mm per turn = (DRO reading/360) X previous mm per turn.
Repeat for accuracy.
Posted: Sun May 07, 2023 7:20 am
by Tamarbarr
This should fix the speed problem is the corners?
Posted: Tue May 09, 2023 1:52 pm
by Joey
Yes
Posted: Thu May 11, 2023 11:15 am
by Joey
Tamar.
Have you tried these changes? I've also noticed a big difference with smoothing on and off. Smoothing on helps maintain target velocity. Have you been running with smoothing on?
Posted: Fri May 12, 2023 12:16 pm
by Tamarbarr
Yes I've tried the configuration that you've told me, it did not do any difference.
I always have the smoothing on.
Posted: Fri May 12, 2023 1:38 pm
by Joey
Tamar please post a fresh Report from the table
Posted: Mon May 29, 2023 9:16 pm
by Joey
Tamar how is your progress? Please post a fresh report and an update when you get a chance.
Posted: Mon Jun 19, 2023 11:42 am
by Tamarbarr
Hey there sorry I haven't been in touch.
I didn't really played to much with the rotary cause I'm still waiting for the laser equipment.
I did tried to cut a few parts on the rotary and I'm having some trouble with it.
For some Reason when I run a program on the rotary plasma with the thc on my z axis is losing steps and therefore the program is failing.
When I run the same program with the thc off I'm able to complete it successfully.
I've spoken with les and this is his response:
"Hi Tamar,
I suspected your Z axis was losing position. There are two possible
causes for the problem. Either the THC is trying to move too fast for
the Z axis motor and making it lose position or the THC is getting
confused by the large Z axis moves while cutting. Does the THC have
separate settings for acceleration and maximum speed or does it just use
the Z axis motor settings? If there are separate settings for
acceleration and speed for THC try reducing them. If not, try reducing
the Z axis motor acceleration. It may be worth having a chat with
Centroid to see if they have any ideas.
Alternatively see how well you get on with running without THC. Your
tube is supported close to the torch so you may well get away with it."
I did as he suggested and lowered the speed of the thc down to 2000, (my z axis max speed settings is 9000) and I also lowered the acceleration of the z axis from 0.5 to 1.5 and it did help a little I think but not completely.
I never had any problems this losing steps with the thc on when I'm cutting sheets.
Also all of my motors have encoders.
Any idea how to solve it?
Posted: Mon Jun 19, 2023 11:44 am
by Tamarbarr
I recorded those videos for les, please take a look.
Video 1
Video 2
Video 3
