If you do not have ENAble connected to the drive, changing it will have no effectBillB wrote: ↑Sun May 15, 2022 3:05 am Marty,
So I selected screw terminal cycled CNC12 and I have motor movement back! YES!!! Thank you. I don't get it I did change that a couple of times but it had no effect?
Question is before I did that I did not uncheck the enable box in the advanced tab. it is currently active. SO do I need to uncheck it now, as I said there is no output for enabled that I know of. In my lathe configuration, the enable box Is not checked.
New Rebuild on Sherline Chucker Lathe & New build on 5400 mill
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Re: New Rebuild on Sherline Chucker Lathe & New build on 5400 mill
You provide no information on the rotary table, no pictures, no specs (What is the worm gear ratio?) does it have a home switch or no?
More info please. Tom explained the rotation.
I need to collect the specs on the rotary. I will have a home switch (if I can find it) that seemed to miss placed the mount. but will get this info together and ask the guys at Sherline what the worm ratio is.
72:1
https://www.sherline.com/rotary-tables/ ... ee%20apart.
72/360=.2 would be the overall turns ratio
Change the Axis to ROTARY
Read the Acorn Installation Manual: https://www.centroidcnc.com/centroid_di ... manual.pdf
Not sure how you are going to setup a repeatable home switch on that small table.
You can manually Jog the rotary axis before setting home.
Thank you for the info Marty much appreciated. I have the Sherline limit switch kit here is it installed. So A+ direction is Counter clockwise and A- is clockwise Is that correct?
A+ is clockwise when looking in the positive X direction
Not exactly sure I understand the way you explained that, lol. Is this correct?
Depends. Which way is X+?
X+ is to the left when standing in front of my machine,
I do have enable circuit wired to my drives, the same wiring as your Emco build. So just want to confirm If I leave the enable checkboxes under advanced checked or turn them off?martyscncgarage wrote: ↑Sun May 15, 2022 9:34 amIf you do not have ENAble connected to the drive, changing it will have no effectBillB wrote: ↑Sun May 15, 2022 3:05 am Marty,
