Emco PC Turn 50 ATC issue
- CNC Control System Serial Number: 3699, 3788
Re: Emco PC Turn 50 ATC issue
Here is a fresh report.
- report_0035FF622356-0206214342_2021-12-06_17-59-43.zip
- (615.49 KiB) Downloaded 69 times
martyscncgarage wrote: ↑Mon Aug 02, 2021 9:47 am You are using the DB25 to connect the sensors correct? DB 25 inputs are 5V logic, Acorn input headers stand at +24VDC DO NOT CONNECT your turret sensors to the Acorn header. Assuming you are using Schematic S14986 for the PC55?
Hi Marty,
is there any way to connect the turret sensors to the acorn headers instead to the DB25 port?
greets
andy
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Why?Andygraphy wrote: ↑Wed Feb 16, 2022 1:40 pmmartyscncgarage wrote: ↑Mon Aug 02, 2021 9:47 am You are using the DB25 to connect the sensors correct? DB 25 inputs are 5V logic, Acorn input headers stand at +24VDC DO NOT CONNECT your turret sensors to the Acorn header. Assuming you are using Schematic S14986 for the PC55?
Hi Marty,
is there any way to connect the turret sensors to the acorn headers instead to the DB25 port?![]()
greets
andy
First you have two turret sensors, one for tool position 1 and the other that counts positions correct?
The issue is that your turret uses +5VDC logic. Acorn header inputs stand at +24VDC and need to be sunk to ground to activate.
You could run your turret sensors into this relay board:
DZS Elec 5V 2 Channel Relay Optocoupler Isolation Module Red Board 3-5V High and 0-1.5V Low Level Triggered Load AC 0-250V / DC 0-30V 10A SCM IO Control
by DZS Elec
Learn more: https://www.amazon.com/dp/B07BDLQB8Q/re ... UTF8&psc=1
Your run +5VDC to the DC+ and DC- terminals, and you run your turret signal lines to In1 and In2
And then use the dry contacts to ground the appropriate inputs:
3= Turret Sync Bit
4= Tool Position Bit 1
hi Marty,
yes correct i have two turret sensors
i ask because i accidentally wired my acorn wrong at the beginning and blow it up
a friend could fix it really good include a new seedboard because the old one seems to be dead...but i have sadly a problem with the DB25 connection... i connected the +5V signals from the sensors to input 3 and 4 with the DB25. the LED`s are switching on the Acorn if they get an signal, but when i look in CNC12 on my diagnostic screen no signal is detected
maybe you know where the problem could be located (on the board)?
Use Centroid's warranty "forgiveness" and purchase a replacement for $199Andygraphy wrote: ↑Wed Feb 16, 2022 2:39 pm hi Marty,
i ask because i accidentally wired my acorn wrong at the beginning and blow it up![]()
https://www.centroidcnc.com/centroid_di ... 0Period%22).
It happens to the best of us...including ME!
What exactly did you do to damage Acorn?
it was a stuppif mistake... i connected one GND wire to the turret control board.. but not an DC one... a AC one... and because of that it got an 220V voltage to the system
IS what it is. It happens. Suck it up and replace it...Andygraphy wrote: ↑Wed Feb 16, 2022 2:51 pmi just give the board a friend who want try to fix it and spend already some cash for the new seedboard and activation
i just dont want to spend another 199$ plus tax and shipping to germany.
I wouldn't pay others to band-aid it.
- CNC Control System Serial Number: 5JP98711918879705-985DADEB78D8-0110180511
How is the turret doing? I'm pretty sure we have the exact same turret. Check my thread "retrofitting emco PC turn 55". Got mine working last week.
