New Centroid Teknic Clearpath officially supported configurations. Updated 5-10-23
embain14
Re: New Centroid Teknic Clearpath officially supported configurations
Post by embain14 »
The tuning was a total success, thanks Franco, the motors are much quieter now!
I was reading the "clearpath acorn success stories" and came across a post from "Centurion". He explained how he was able to get his Z axis to fault by driving it hard up and down. Using this method I was able to recreate the attached fault with the spindle on, but when the spindle is off I cannot get the fault. I think its electrical noise that is the cause of all my Z axis position loss!
UPDATE: I went ahead and separated all the clearpath wires from the spindle power wire inside the cable track and I can no longer re-create the fault!!! I still plan to add the resistors in the next week or so because I am still experiencing erratic behavior.
UPDATE2: repeated hard drilling cycles caused the same fault to occur, the plan is still to add resistors (drilled about 20 5/16" holes in 3/4" plate before error occurred). Should I consider adding EMF shielding to spindle wire in cable track?
UPDATE3: I added the resistors per the schematic at the start of this thread (100 ohms to 5v) and the result was NO movement at ALL! Am I really going to need to buy all new cables since I cut the molex connectors off and buy a C86ACCP board??? I just ordered up some 10k resistors, I'm going to hook those up to 24v and see if thats any better.....
UPDATE4: I'm happy to report that the 10k resistor, 24v combo on the step, direction and enable worked flawlessly, I ran over 24,000 lines of code (peck drilling hole grid pattern in table top) without a single missed step! Resistors were cool to the touch after the program was complete. Again, the mill ran just fine for extended periods on time without the resistors but after about 10 minutes the timing error came up on the MSP software. With the resistors this is no longer a problem.
ALL,
As of today, CNC4PC has a few of the first run of boards with both the Molex AND the terminal blocks. They work fine but they are making some minor modifications to slightly improve them. The next run of boards will take about 30 days to arrive. (Toward the end of May 2021)
Here are a few pictures of the new board:
Quickie video on the preliminary board I was sent to test:
TaylorPilot
Post by TaylorPilot »
Just got mine with the terminal connectors today. Getting ready to connect to the computer for the first time!
sakumar
Post by sakumar »
Hello all,
I'm using the Acorn board with C86ACCP and Clearpath servo motors on a Precision Matthews 728VT mill. I'm not using the VFD function of the Acorn to control the spindle. The spindle is a DC motor.
However, I'd like to stop the spindle when there is a drive (i.e. Clearpath Servo Motor) fault.
How do I go about doing that? Can I use the Relay OUT1 to stop the spindle? If so, how?
I've already got it so that my E-stop (in addition to disconnecting the Acorn's E-Stop (Input 8) from COM), also disables the spindle motor using a contactor.
But if a servo motor signals a High Level Feed Back drive fault to the C86ACCP how do I stop the spindle in that case?
Sanjaya
Sanjaya, start a new post with your question and it would get more attention than on this thread.:-)
Rawfodog
Re: New Centroid Teknic Clearpath officially supported configurations. Updated 1-24-22
Post by Rawfodog »
I am having issues with my accuracy.
If I jog .100 my router moves .5
I am using the settings provided in this post but not having any luck.
Am I missing a step to tune the distance
I am using an Avid CNC 5'x12 Pro router kit.
Rawfodog wrote: Mon Apr 04, 2022 9:47 pm I am having issues with my accuracy.
Yes, you are missing a step to set up your overall turns ratio but as previously stated by Keith, please start a new topic with your question and please be a lot more specific with motor and drive data and a copy of a current report from the machine.
Rawfodog
Post by Rawfodog »
thanks
Re: New Centroid Teknic Clearpath officially supported configurations. Updated 5-10-23
I updated the first post with new documents and links.
- Detailed user install info from Gary Campbell on C86 install. Gary's Edit of the CNC4PC manual.
https://www.centroidcnc.com/centroid_di ... ttings.pdf
- Related reading. Centroid Clearpath Hard Stop Homing How to doc.
https://www.centroidcnc.com/dealersuppo ... ds/319.pdf
- link to router gearing advice. https://centroidcncforum.com/viewtopic.php?f=63&t=8649
