Advice re upgrading to Acorn from Mach3 and Ess
- CNC Control System Serial Number: 0035FF8A7F34-0730203594
Re: Advice re upgrading to Acorn from Mach3 and Ess
How can I tell if the rating advertised by the seller is quadrature or, lines per revolution? When I try to install the encoder I purchased, will I use the rating that the seller provides, or divide / multiply by a factor of 4?
I'm very confused and concerned now.
I suspect that I will just have to try it and see.
Encoders are sold as PPR.dmbgo wrote: ↑Wed Aug 19, 2020 5:59 pm How can I tell if the rating advertised by the seller is quadrature or, lines per revolution? When I try to install the encoder I purchased, will I use the rating that the seller provides, or divide / multiply by a factor of 4?
So, the encoder I have ordered is listed as "3600 PR" does this mean that it's 3600 PPR, 1000 lines, or 14,400 quadrature P/R? Or does it provide 900 pulses per revolution extrapolated to 3600 pulses per rev?
You have purchased a 3600 PULSE PER REVOLUTION ENCODER
It will yield 14,400 counts because of the A, /A, B, /B pulses
Watch this short Centroid video:
Watch this video to understand the term "Quadrature" (note: he is using a "single ended" encoder Just an A and B channel):
Reason: clarify counts vs. pulses
Phew, thanks Matty, so it will meet the specs on the Acorrn graphic.
Thanks for that.
Thanks for that.
Maybe and maybe not. You chose to by a Chinese copy of a brand name encoder at a higher resolution. Only good thing is you can change it out if it doesn't work out. You really don't know what the quality *might* be. I personally choose to by reasonable quality components from reputable sources here in the US. I use automationdirect.com a lot and have purchased Centroid's encoders as well.
Yes, the "quality" is a gamble, but in the past I have been happy with that. If it doesn't perform per its specs, I'll get a refund and spend the $ to buy a genuine one.
I appreciate your help and advice Matty / Marty. (Have I been calling you by the wrong name?)
You are asking us for advice, we are giving it to you.
One last piece from me. Buy once, cry once....
I have a drawer full of wasted purchases....
Hint in my username....
