slodat
Re: Hardinge Accuslide Gang Tool Lathe Acorn Conversion
Post by slodat »
Control panel sitting on the lathe.
Turned out nice!
slodat
Post by slodat »
Finally getting to wiring in the new control. It’s a lot in a small space.
roundel325
Post by roundel325 »
Wow! I'm impressed with your component placement and wiring tidiness, considering the space constraints. The labeled shrink wrap are things dreams are made of.
slodat
Post by slodat »
Made a little progress on the lathe today. There are plenty of holes for cable pass through in the enclosure.
Drew up a snap together cable gland that uses existing holes and fasteners.
Holds the cable nicely.
Very nice!
CivilCNC
CNC Control System Serial Number: will obtain
Post by CivilCNC »
How is this project coming along? I just aquired a CHNC chucker and Im interested in seeing your encoder setup
Looks awesome!!!
Nice work, looks great thanks for sharing your ideas
slodat
Post by slodat »
CivilCNC wrote: Wed Jun 15, 2022 5:53 pm How is this project coming along? I just aquired a CHNC chucker and Im interested in seeing your encoder setup
Looks awesome!!!
Slowly. I have everything for the conversion, work on it when I have time.
slodat
Post by slodat »
Almost done with wiring on the lathe. Waiting on some stuff to arrive to finish the encoder wiring and I'll be done.
Lower cabinet:
There are a few spots that could use a blanking plate. 3d printed this one. Worked out well.
It looks like originally there was a cover for the axis ball screw. It's long gone.
Cut this out of 12ga mild steel. It's way over kill, but the sheet was on the plasma. Worked well.
Close to be wrapped up.
I have a lot of learning to do before I'll be doing anything meaningful with the lathe. I ordered a few tools. I have a lot of tool holders I bought a while back. Need to get a small assortment of tools and sort out using the conversational programming to make a part. The encoder will allow for threading.
