Laser Setup options will be in the Laser setup menu.
1.)
G64 modifies the geometry by definition, it is not intended nor has it every been recommended by Centroid to be used with Laser cutting or engraving.
I think this confusion can from Avid making a check box in there version of our Wizard that says "Laser Smoothing".
That being said, would there be a Laser g code case that G64 could help with? possibly, We didn't need it during our Laser testing to get good results.
Adding G64 into the mix will result in unintended consequences, your results may vary. This falls into the experimental category since the way G64 works is radically different than the regular machine motion algorithm.
2.) Currently diode laser power isn't powerful enough to 'outrun' the machine, and while i have no doubt that there is a delay from the time the command is given to the laser head to the laser hitting the material currently this occurs outside the parameters of useful functionality (the laser isn't strong enough to make the burn you want for that little bit of time that it is on the target) That being said some day there will be affordable Lasers on the market that will be powerful enough to out run the machine. so for now, an offset feature is not needed to get great Laser cutting results with a Centroid.
https://www.centroidcnc.com/dealersuppo ... ds/326.pdf In the future we could add a delay compensation feature.
