Denford Triac Carousel ATC
Re: Denford Triac Carousel ATC
Can I also check. plc.src, where is that? I can only see acorn_mill_plc.src. Is that in effect the file you are referring to?
Also, I can see ATCCarouselReverse and ReverseToolTurret (as an option in the ATC dropdown). Is there a specific use case for either? It sounds like the first is for a typical Carousel and the 2nd might be on a lathe?
Mario did a whole series of video's on plc programming. Its a lot of information but I would give them a watch first.
Thanks. Had started to watch however also a bit time limited. Let me look at that again.
you will need to compile it correctly and yes that is the right plc file. You are also correct about the ToolTurret being for a lathe style atc. Learning custom PLC can be a big time suck but understanding it will save a lot of frustration. Centroid is easy to use but getting my atc working correctly was by far the most difficult part.
Guys, what's wrong with this, why cant I trigger an output on the Ether1616?
This is M63.func that I'm editing so that I should be able to use M63
; Filename: mfunc63.mac
; Wizard ATC_CarouselIn M-code Macro: M63
; Description: User Customizable Macro
; Notes: Use Acorn Wizard i/o map to set Eth1616 to 33 for ATC_CarsouselIn
; Requires:
; Please see TB300 for tips on writing custom macros.
IF #50010 ;Prevent lookahead from parsing past here
N100 ;Insert your code between N100 and N1000
M94 /63 ;Request ATC_CarouselIn
N1000 ;End of Macro
How else can I trigger Output 33 onwards on the Eth1616 via a Macro?
I realise the Request is behind a ; comment, so how do I define it?
; Requires:
N1000 ;End of Macro
Why does this code M94/120 or M94/117 do nothing? 120 is not mapped (says output 36, so tried 117 which is 33, surely)?
Page 12 in this manual refers - https://www.centroidcnc.com/centroid_di ... ctions.pdf As the ATC code does use the outputs, it does exist. Why cant I manually enable / disable via M Codes? I dont want to use the default macro as it doesnt work for me and I'd prefer not to edit the .src as I believe I can emulate what I need via Macro however I have to be able to manually trigger an Ether1616 output. I can move it to the Non Ether board but that defeats the purpose - what am I missing please?
Is there meant to be anything define here in the .src file like the M61 to M68 is?
OK. Ive moved on from trying to do it this way and using Outputs that I can actually address. This is all working fine and I have some base automation sorted. Just working through the detail of how to count / decrement a counter each time an input changes state .... so that I can tell how many times the geneva motor has rotated. Any tips would be appreciated.
N300
#151 = #4120 ;Save the requested tool change into variable 151, might not be needed but it's there.
#152 = #4203 ;Save the current tool as variable 152, as per above.
#155 = (#4120 - #150) - #152 ;Variable 155 is the number of times I believe the geneva wheel needs to turn (might not be accurate but I can figure it out later).
;Code to determine Rotate Carousel
M68 ;Rotate Carousel FWD - switch on the Carousel Forward
;Code to count / decrement the 155 variable (this isnt working at the moment)
N310
M101/50033 ;Wait for a trigger on the 1st Acorn Eth1616 Input
#155 = #155 - 1 ; If I see an input on Eth1616 1'st input port, then decrement Var 155 with 1
G4 P1 ;To stop this happening immediately, I wait a second
IF #155 == 0 THEN GOTO 325 ELSE GOTO 310 ;
How else can I count and increase or decrease pending a input changing state please?
N300
N310
OK, slow progress, struggling with M225 but got some working (ironically just copied / pasted someone else which worked and mine was identical), but nevermind.
How do I customise message? If I want to display a value which is calculated and stored in #155.
M225 #100 "The Calculated value in 155 is ... " #155 ?
This doesnt work.
This doesnt work.
