Page 4 of 8
Re: New Build LMS 3990 Hi Torque Mini Mill
Posted: Tue Apr 09, 2024 3:16 pm
might be the balls clicking, cheap ball screws make that noise.
Posted: Tue Apr 09, 2024 3:24 pm
by cdiseker
Might they need adjusting of some sort?
Posted: Tue Apr 09, 2024 5:16 pm
by cdiseker
cdiseker wrote: ↑Tue Apr 09, 2024 3:24 pm
Nevermind...I just found out they do not. Saw a 3d model of how they work. Now I get it.
Posted: Thu Apr 11, 2024 1:38 pm
by cdiseker
Flood Pump Question:
The company that did my build said if I later want to add coolant its easy. Well, I want to add a flood pump. His suggestion was to DIY a small 110v fountain pump submerged into a 5 gallon bucket of coolant and use one of the relays connected to the main board as an inline switch.
Does this sound correct?
Manual Tool Changes on CNC
Posted: Wed May 01, 2024 12:02 pm
by cdiseker
Okay, I'm about to cut the Titan 1M model (in delryn). I'm using Fusion360, Swissi Post Processor, Centroid CNC 12.
Here is my question: I have to perform manual tool changes. Will the "system" recognize this or do I have to modify code some how?
Posted: Wed May 01, 2024 12:35 pm
by suntravel
If you use manual tool change in Fusion, you will be prompted to change the tools.
Posted: Wed May 01, 2024 12:56 pm
by cdiseker
suntravel wrote: ↑Wed May 01, 2024 12:35 pm
From what I've searched this is a paid feature. Is there another way?
Posted: Wed May 01, 2024 1:01 pm
by suntravel
No clue, I have a fusion abo, because I make parts to sell.
Posted: Wed May 01, 2024 4:36 pm
by cdiseker
Good for you. I'm trying to get there too.
Posted: Wed May 01, 2024 5:09 pm
by tblough
If you are already doing manual tool changes, post each tool path as a separate file. Then, just do the tool change before running the file.
