lathe spindle question
Re: lathe spindle question
Turn off Window's "Hide extensions for known file types". My guess is your file is actually named compile.cmd.txt which will not work.
Thanks Tom, I had checked this
- Web Developer
- Hickory CNC Controller: Yes
Midy,
Just had a look at your report that you posted earlier today. In the report.txt file listed in the report.zip, it is showing that you have compile.cmd in the C:/cncm directory.
Directory of C:\cncm
...removed other items for brevity...
Tue Oct 15 19:34:46 2024 43 compile.cmd
The file size and timestamp match what I have here. You should be able to compile, based on that.
How computer savvy are you? Are you able to open Command Prompt? On Windows 10/11, you should be able to search the Start Menu for cmd and it should show up.
With Command Prompt open, can you enter this command?
C:/cncm/compile.cmd acorn_mill_plc.src
If that command works, then something isn't setup right with your Notepad++ install but you can always call the command to recompile acorn_mill_plc.src into a mpu.plc. For lathe, the command would be "C:/cnct/compile.cmd acorn_lathe_plc.src" as was mentioned earlier.
You mentioned updating from 5.26 to 5.30, have you finished the upgrade yet? If so, please post a fresh report.
While you have the CMD prompt open, you could enter the following two commands:
In my opinion, some people spend far more time trying to figure out how to get PLC programs to compile from within NotePad++, than they would spend just learning how to compile a PLC program.
Compiling from a command prompt always works, regardless of whether NotePad++ is installed or configured correctly on that particular computer.
cd \cncm
mpucomp acorn_mill_plc.src mpu.plc
3 users liked this post
To be clear, to address the target file "acorn_mill_plc.src", you must have the current working directory of the command prompt set to the same directory as said target file.
Marc's directions have you first move the current working directory to cncm which contains both, hence the lack of full paths in the second line.
If you are not familiar with command line usage, you can verify the working directory with the command and the contents of said directory with
pwd
dir
1 user liked this post
Thanks for the great replys chaps. Duly noted and will give it a go for sure but im going to do a fresh install of cnc12 soon to update it. And see iff that also sorts this?? We will see? Probably tomorrow - thanks again for all the support
