Page 4 of 4
Re: Choppy motion - VCarve?
Posted: Thu Feb 09, 2023 3:18 pm
by MSimeone
Sword wrote: Thu Feb 09, 2023 3:09 pm Set it on Precision Router and cut some test parts to check for accuracy and possible rounded corners. Mine are always spot on, but the faster you feed, the more chance of rounding there might be on sharp corners (below 90º).
Gotcha, will do. Thanks for the tip. I'll read through the manual on it... I think if there is a size threshold on sharp corners it probably won't be a problem. I generally don't need to do fine small work. The smallest instance of something like that that I can think of would be something like cutting bowties.
