Re: Going from V4.62 to V4.82 PROBLEM
Posted: Wed Jan 18, 2023 12:00 am
Awesome, thank you.cnckeith wrote: ↑Tue Jan 17, 2023 11:55 pmShawnM wrote: ↑Tue Jan 17, 2023 11:52 pmCan you add the drive configuration xml file? I have a custom one that is saved in resources\wizard\saved\drives. This is saved in the report.zip file and can also make the setup go a lot faster my simply importing this XML fil back into CNC12. I don't know if others "export" this XML file for their own setup or not but they should as it helps setup the drive, input and outputs much faster.
yep! thanks for the reminder ..will do.
I use a drive called DYN4_DB25,xml. I think it came from Centroid - it was part of a solution to my noise issues with the DMM drives. Is this a "standard"? I t was one of those items I had to go find during the update process.ShawnM wrote: ↑Tue Jan 17, 2023 11:52 pm <snip>
lavrgs wrote: ↑Wed Jan 18, 2023 12:47 pmI use a drive called DYN4_DB25,xml. I think it came from Centroid - it was part of a solution to my noise issues with the DMM drives. Is this a "standard"? I t was one of those items I had to go find during the update process. < DNY4 DB25 is standard and included with the latest version, not sure why you didn't see it.>ShawnM wrote: ↑Tue Jan 17, 2023 11:52 pm <snip>
The other area that I would like to see improvement is the transfer of wizard inputs. The current method of taking screen shots is pretty clunky...Is there a file that represents the Wizard config? < thats what i outlined above.>
Yes, that is in the works for v5.0ShawnM wrote: ↑Wed Jan 18, 2023 12:11 am
Awesome, thank you.
Will it be possible to save the "profile manager" in the plasma version? I've created many custom profiles just for holes from the existing profiles. For example I take the Steel-65A-.5 profile and copy it and make is Steel-65A-.5-Holes and then modify the feed rate to about 60% of the book number. I prefer to do this rather than adjust the feedrate override on the VCP as adjusting the feedrate override also slows down the touch off speed by 60%. When I have to cut 600 holes this saves me a lot of time just waiting for the touch off cycle.![]()
Yes, you guys are awesome.cnckeith wrote: ↑Wed Jan 18, 2023 2:27 pmYes, that is in the works for v5.0ShawnM wrote: ↑Wed Jan 18, 2023 12:11 am
Awesome, thank you.
till then just copy over any of your custom profiles from the old folder to the new one and they automatically show up in the profile manager. nice that we did it that way!
I'd like to know this too. Just upgraded from 4.62 to 4.82 and lost my G28s & G30s across multiple WCSs (mostly the location of my tool setter). I can re-create them, but it'd be nice to know what file this lives in for future upgrades.
