Acorn CNC12 v4.80 has been released. (8-12-22)
Re: XY Jogging now available. Test it out... V4.80 Release Candidate Now available.
Spartan117 wrote: Fri Jul 29, 2022 4:05 pm
cnckeith wrote: Fri Jul 29, 2022 9:04 am by "hot keys" are you referring to keyboard jogging? or the VCP?
Sorry, I am talking about all existing keyboard-shortcuts.
The ones of the jog-panel can be displayed, but all the others like described in the manual starting at page 25.
Alt-I, CTRL-E, Alt-J itself and so on.
I want to make a simple and easy to use 1-page-cheatsheet for pinning at my machine that lists all that 3 pages.
Therefore i wanted to know if something has changed or came up new since the last manual-revision.
Okie dokie. Thanks for the explanation. Yeah, I don't think there's been any changes related to the keyboard. Shortcuts. Ever since the VCP was developed PC keyboard jogging and hotkeys have kind of gone to the wayside.
a new RC was just uploaded today at 5:40 pm EST (8-5-22). same download link.
- added better support for C axis and 4th axis wireless mpg jogging in Lathe
- improvements and additions to Plasma Intercon conversational programming
Cool.
Now I can control all 4 axes with lathe on the WMPG, thanks.
Needs some different PLC mod to use the WMPG macro buttons not for macros...
Y on the lathe will bring out "501 invalid character" like before in MDI or program, but B linear works.
Acorn CNC12 v4.80 Mill, Lathe, Router and Plasma has been released.
refresh this page to see latest.
S1Loki
CNC Control System Serial Number: C147127
Re: Acorn CNC12 v4.80 has been released. (8-12-22)
Post by S1Loki »
I have been playing with the beta version a little. I fired it up last night to find out it had expired. So its time to upload the actual release version.
GBCues
CNC Control System Serial Number: noneC120192
Problem with Upgrade
Post by GBCues »
All,
I'm sorry to report I'm having a problem after upgrading.
It looks to me like the funcion of DriveOK has changed.
I use it on Input5 to trigger my contactor which then powers my power supplies for my drives. Input 5 goes green, but my contactor doesn't activate.
Report attached.
What did I do wrong?
Gary
report_3403DE5D9CDA-0612192141_2022-08-22_14-21-50.zip
(725.1 KiB) Downloaded 28 times
GBCues
Post by GBCues »
I renamed the CNCT directories to revert back to CNC 4.62 and the machine comes right up.
Report file from this build is attached.
Gary
report_3403DE5D9CDA-0612192141_2022-08-22_14-35-18.zip
(592.39 KiB) Downloaded 27 times
Sword
Post by Sword »
I believe it's that you don't have Output8 set as NoFaultOut.
Scott
GBCues
Post by GBCues »
Sword,
Thanks, but I checked the current Centroid-recommended wiring schematics for my drive and it hasn't changed.
Input 5 is DriveOK
Input8 is EStop.
I'm not sure where you got your recommendation from.
Gary
Input8 != Output8
