So I bought a unused/used "buildyourcnc"
drdennis
CNC Control System Serial Number: 0927215221
Re: So I bought a unused/used "buildyourcnc"
Post by drdennis »
As for the 1422.22 steps per in. the machine I have is sprocket & chain driven, is it telling me that it takes less than 1 motor revolution to travel 1"?
Yes it does, assuming 16x microstepping (3200 for full revolution). Glad you got the math under your belt.
Cheers
related reading.
viewtopic.php?f=63&t=1801
metalman2
CNC Control System Serial Number: 1442FC0CB1C3-0813215081
Post by metalman2 »
drdennis wrote: Wed Nov 24, 2021 4:18 pm
Cheers
So if that's the case do I need to set the axis wizard at .8888 rev per inch? Thanks for all your help by the way!
metalman2
Post by metalman2 »
On the drive it has 8 dip switches but no information is given for switch 4 or 8. What should those be set at? I've read to leave them at factory settings but I'm not sure what that was..
metalman2
Post by metalman2 »
drdennis wrote: Wed Nov 24, 2021 4:08 pm Yeah, that's wrong. The Acorn doc is a bit skimpy on defining the DB25 outputs but it is suggesting 5V positive logic, so you have it wired backwards. No worries the LEDs on the CW230 input just won't work like this -- no damage.
You need to feed the DB25 signals to the positive inputs and tie the two negative inputs to the ground (e.g., pin 18)
That worked... I have movement! Thanks
drdennis
Post by drdennis »
Great, now you can play with the microstepping and current settings to get more comfortable with what those parameters do in real life. When playing, if you can still touch a motor with your hand (<70 deg C) you are OK.
Regarding the two micro switches you mentioned: 4 and 8, the doc I found contains a pretty incoherent paragraph talking about 1/2 current (while not mentioning which of the two switches controls that). Guessing based on controllers I have used, it is more likely that switch 4 controls that function. The switch allows you to cut the current in half when the motor is stopped. You should be able to play with it and feel the difference as the torque will also be cut in half.
I am guessing the other switch does not do anything. But you can always check if there is any affect. Remember to turn the power off when you play with the switches. Good luck!
Cheers
metalman2
Post by metalman2 »
So it's up and running! Thanks everyone. I've played around with some of the conversational programming and it's great. Do I have to add the pro license to run larger programs? I'm not sure if the acorn came with that license when I purchased it. Thanks
centroidsupport
Post by centroidsupport »
Sorry if I missed it but I didn't see a report. Please post one. The control system serial number you show doesn't bring up anything. The report
will show everything I need to reply.
Free version is limited to 20 Intercon blocks. Pro and Ultimate have no limit.
metalman2
Post by metalman2 »
centroidsupport wrote: Fri Dec 17, 2021 8:34 pm Sorry if I missed it but I didn't see a report. Please post one. The control system serial number you show doesn't bring up anything. The report
Sorry, I'm still new at all this. Hope this is what you need!
report_1442FC0CB1C3-0813215081_2021-12-17_19-29-06.zip
(635.12 KiB) Downloaded 643 times
