Huanyang HY03D023B, 12000RPM Max Speed
Re: Huanyang HY03D023B, 12000RPM Max Speed
tuffduck wrote: Fri Aug 06, 2021 6:34 pm The speed can be adjusted correctly from the front panel. The model I have is not in the manual. PD003,PD004,PD005 cannot be set to 60. The spindle will not turn at these settings. These are the only setting I have changed after a Factory Reset.
PD001 1
PD002 1
PD003 300
PD004 300
PD005 300
PD006 2.5
PD008 220
PD011 200
PD014 10
PD015 10
PD070 0
PD072 300
PD142 8.6
PD143 4
PD144 3000
PD1PD176 1
I am at a loss. Contact Huan Yang for support.
If done a number of these drives and have not had the problems you are having.
How about a shot of the motor nameplate.
I am wondering whether or not you have a knock off of a Huan Yang inverter. Where did you get it?
tuffduck
Post by tuffduck »
The spindle came on the machine.
tuffduck wrote: Fri Aug 06, 2021 7:19 pm The spindle came on the machine.
Chinese water cooled router spindle? No markings on it, no specs?
tuffduck
Post by tuffduck »
Sorry, spindle plate. Air cooled.
tuffduck
Post by tuffduck »
tuffduck wrote: Fri Aug 06, 2021 7:35 pm Sorry, spindle plate. Air cooled.
Thank you for posting the nameplate!
I assume this machine came with the VFD and Spindle.
The nameplate clearly suggests it is to operate at a fixed frequency of 300hz and spindle speed of 18K rpm
It appears the VFD is locked and will not let you lower that frequency.
If you happen to go below it, it may overheat.
So it appears in your case, its spindle on and spindle off. No variable speed.
300hz=18Krpm
I would wager there must be some sort of password protection set in the VFD.
My .02 with the new information presented.
You can *try* and ask the manufacturer if you can very the speed of the spindle motor, my guess is a no because the cooling fan won't spin fast enough to keep the motor cool.
My .02
tuffduck
Post by tuffduck »
I sent the info to the manufacturer to see if they can help out.
He stated the speed can be adjusted from the front panel on the VFD just fine. I don’t think it’s software locked. The fan should be independent of the spindle speed, my HSD spindle has a cooling fan that runs independently from the spindle.
Do you happen to have another spindle laying around you could try? Without an exact manual for your VFD it’s hard to know if it’s even programmed correctly. Contact the machine manufacturer and ask them for a manual.
tuffduck
Post by tuffduck »
Sorry, no other spindles.
Gary Campbell
Post by Gary Campbell »
I've used a number of those spindles. Air cooled, shaft mounted fan. Range 9-18k rpm
