Installing the Acorn with Adtech CNC drives
Re: Installing the Acorn with Adtech CNC drives
Will be tomorrow before I get a look at it....
dmbgo
CNC Control System Serial Number: 0035FF8A7F34-0730203594
Post by dmbgo »
That's fine Marty, The time difference between you and me is large :)
dmbgo
Post by dmbgo »
Muzzer wrote: Sun Aug 30, 2020 5:46 am I notice it also has forward and reverse inhibit inputs, pins 12 & 13. These need to be grounded.
Page 38 suggests max frequency for step and dir is 200kHz.
Page 79 shows how to jog the motor from the servo front panel. If you can't do this, it won't work in your system.
http://www.robosan.com.tr/pdfs/QS5%20SE ... MANUAL.pdf
Both of the forward and reverse inhibit inputs, pins 12 & 13 are negative, I thought they would need 12 . 24v to be active?
12 CW- ARE
TURNING
LIMIT
13 CCW- REVERSAL
LIMIT
You're right about the pulse frequency for single ended inputs, it looks like it is 200khz
I haven't got 79 pages in the QS6 manual, your url points to the QS5 manual.
I'm using : http://www.robosan.com.tr/pdfs/QS6-Manual.pdf
Muzzer
Post by Muzzer »
On page 16, I see differential mode inputs for step and dir are up to 500kHz. In single-ended, it's 200kHz. But I don't think that's your problem here.
Do you not have the tuning software? It's got to be easier than either guessing what the Chinglish manual means or trying to run diagnostics from the front panel. The manual's not clear how some of the inputs are set up - for instance are the forward and reverse inhibit inputs active high or active low etc.
Servos drives have a lot more setup options than VFDs, so there's plenty to get wrong.
dmbgo
Post by dmbgo »
Sadly there is no tuning software that I can find for these drives. They were however working before with mach3. I began to doubt it myself, but managed to resurrect the old setup and they worked again with the old controller. At least I know for certain now that they can work using the same cables and a step and direction input.
dmbgo wrote: Sun Aug 30, 2020 8:54 pm This is my Word doc of my connections for the ESS.Lathe RJ45 Cable for Adtech QS6 Servo drives (2017_09_15 23_35_09 UTC).doc
I looked at your document. You do not have listed the functions of the pins (what they connect to) on the control side.
Yes, if it works with MACH it should well work with Centroid. If its working under Mach now, leave it that way until we figure things out.
Need to see pin functions from the control side to the drive side. I do something similar but I do it on an Excel spreadsheet. On one side, the drive pin number, next to it the function of that pin, then the control side the function of that pin and what grounds and voltages go where.
Muzzer
Post by Muzzer »
Incidentally, if you look on the Adtech website, the servo software is available for download. Its currently at QS7 but I expect it will also support QS6.
It's at the top of page 4: https://www.motion-control.net/download-4 "QS7 software"
A whole new world of Chinglish awaits you, should you go that route...
dmbgo
Post by dmbgo »
martyscncgarage wrote: Mon Aug 31, 2020 10:51 am
I have been careful right through to avoid changing any setup, until I know what I am doing and why. I try to avoid the potential trap of changing more than one thing and then solving the issue, only to have it still not work because of a different change that I made earlier.
Its much easier to work from the "known to the known" rather than "the unknown to even more unknown" :)
That being said, I am starting to wonder if it may have possibly been working all along, and I'm just not understanding the Acorn user interface properly?
Here are my methods of testing:
1/ Press the reset button so that the button says "Reset Ok", get the Axis dros to display 0 using the green cycle start button (which is not labelled) and use the Jog Keys Z+ and Z-. I see the Dros change when doing this but no motot movement.
2/ Use the MDI and type something like G0 Z100, then press enter on the keyboard and Cycle start. The relevant Z DRO changes to 100, whilst displaying the feedrate oif 600mm per min.
dmbgo
Post by dmbgo »
Additionally Marty, when you say I am missing information on the document I sent you regarding connections on the "control side", what do you mean? I can provide any extra info you need.
dmbgo
Post by dmbgo »
Muzzer wrote: Mon Aug 31, 2020 1:40 pm Incidentally, if you look on the Adtech website, the servo software is available for download. Its currently at QS7 but I expect it will also support QS6.
Muzzer, thank you for the software link, I looked long and hard (but obviously not hard enough) for this software. I see what you mean about Chinglish though. I won't deviate from my current path to explore the depths of this, but rather continue for on my current path...
(unless you think I should?)
