DT02 Tool Touchoff Sensor - SUCCESS
cbb1962
Re: DT02 Tool Touchoff Sensor - SUCCESS
Post by cbb1962 »
cncman172 wrote: Thu Feb 21, 2019 5:52 pm How did you compile the code? Did you use the Wizard or do this manually. If you do it manually it will show you the error. I can even post my two files and then you will need to go into the wizard and adjust you inputs, outputs, etc.
I tried to use the wizard, failed. Went back and compiled as you did, It worked!
Clint in NW Arkansas
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Glad you got it working
Russ
