GHOST? Noise? Bad Luck? Could use some ideas..
Re: GHOST? Noise? Bad Luck? Could use some ideas..
Some, why and how in this video: https://youtu.be/TLOtXTOSUWo
- CNC Control System Serial Number: C8FD19F24C5C-0213180656
Wow, no clue how I haven't run across your videos! Great work!
Gary Campbell wrote: ↑Wed Mar 14, 2018 7:34 am Some, why and how in this video: https://youtu.be/TLOtXTOSUWo
Wired up the resistors and axis would move at all. Looked at the manual a little closer and it only calls for added resistors when the voltage is above 12v. So if I'm reading this correctly, it doesn't apply to the Acorn setup and I was wired according to the manual from the start.
Going to give the DB25 connector a try when it comes in tomorrow. After that I'm pretty much out of ideas.
diycncscott wrote: ↑Tue Mar 13, 2018 2:19 pm Do you have a manual for your drives? (DMA860H)
I can't find one and would suspect you should follow the diagram in your Leadshine manual. We try to post schematics that work with various models but, when in doubt, always make sure your drive is wired per the drive mfg. spec.
BTW Not having those resistors as depicted in the Leadshine manual would definitely make the drive more susceptible to missing pulses/steps.
Tried the DB25 route. No luck, exact same behavior. Looks like it is probably time to throw in the towel.
Support- Let me know if you have anything else you want me to try before I package it up to send back.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
As a test
Can you drop your Z axis max feed rate to 75 and max jog rate to 75 and rerun the part. See if it's accurately cut.
Yes, I know Z will be slow but is a test.
Acorn is not your problem....
Let us know if you give it a try and what the result is
Thanks for the continued assistance. I just started the test run with those parameters.
Thanks!
Adam
Thanks!
Adam
martyscncgarage wrote: ↑Fri Mar 16, 2018 10:30 am As a test
